Danalock V3 (New FW 0.20.0) Losing Connection
That shows only a /light resource, no ZHABattery resource.
(Look at FYRTUR block-out roller blind - deCONZ REST-API)
Seems that battery is not exposed.
Sure, but I can’t really do anything without the API output. Given that the Battery sensor implementation is very generic and no other issues have been raised, I would still be inclined to believe its on the device support side of things.
I have a device. How can I help?
List the device description using phoscon gui should give you the rest output for th device. I’m not entirely sure how to do it.
The other way is enable debug logging in deconz integration and share the logs
Not possible with cheking direclty in the API ? using Phoscon/help/API Information ?
Hi guys!
Here is the latest release of the DDF. You can get it just here ftm. It will be also in our next deCONZ version.
The battery status is now transmitted. It appears in the API as an extra sensor, but is not yet displayed in the Phoscon app. However, it will be available via HA systems.
danalock_v3.json (3.4 KB)
