This is a duplicate to [MacOS] Error flashing firmware · Issue #21 · dresden-elektronik/gcfflasher · GitHub but I guess it’s easier to find support here than on GitHub.
I followed the steps on the Readme.md
to build the gcfflasher
tool for MacOS.
The build was (I guess) successful, as there were no errors and I can list the device with gcfflasher -l
Despite listing, the tool doesn’t seem to work. I tried the command for reboot and flash firmware. In both cases, the tool crashes.
./gcfflasher/build/GCFFlasher -r -d /dev/cu.usbserial-DExxx
PL_Connect
connected to /dev/cu.usbserial-DExxx, baudrate: 115200
send: C00D0500090000000000E5FFC0 (13)
send uart reset
send: C00B03000C0005002602000000B9FFC0 (16)
invalid CRC
recv_packet: 0D0500090000094E26 (9)
recv_packet: 818204000100105B77FC (10)
shutdown
PL_Disconnect
./gcfflasher/build/GCFFlasher -f deCONZ_ConBeeIII_0x26510900.bin.GCF -t 60 -d /dev/cu.usbserial-DExxx
read file success: deCONZ_ConBeeIII_0x26510900.bin.GCF (181950 bytes)
GCF header0: magic: 0xCAFEFEED, type: 60, address: 0x00004000, data.size: 181936
GCF header1: product: 0xDEC0DE03, img.type: 61, img.address: 0x00004000, img.data.size: 181900, crc32: 0x7ABA8D12
flash firmware
PL_Connect
send uart reset
recv_packet: 8104000000000001 (8)
invalid CRC
PL_Connect
device already connected /dev/cu.usbserial-DE03216114
query bootloader id V3
send: C081027DFFC0 (6)
bootloader version 0x00010004, app crc 0xFC775B10
send: C08103B0C60200004000003CAAAAAAAAE0FAC0 (19)
recv_packet: 818300 (3)
BTL data request, offset: 0, length: 256
zsh: trace trap ./gcfflasher/build/GCFFlasher -f deCONZ_ConBeeIII_0x26510900.bin.GCF -t 60 -d
In both cases, an invalid CRC
seems to be the issue. I also tried it with sudo
with the same unhappy result.
