I am trying to connect Tuya application to Phoscon gateway but it did not find it even if I press “Authorize app” button. It is possible to connect it?
I don’t think it is.
That means is not possible to use the native app of the manufacturer with the zigbee devices connected to Phoscon gateway?
That is indeed what it means. I recommend reading this to have a better understanding of how deCONZ/Phoscon works: deCONZ for Dummies · dresden-elektronik/deconz-rest-plugin Wiki · GitHub
Thank you.
In this case what’s the point of “Authenticate app” functionality? I was expecting that there is a standard way for apps and gateways to authenticate and then communicate. This is not the case?
More or less , you can use it for exemple with https://play.google.com/store/apps/details?id=com.superthomaslab.hueessentials&hl=fr&gl=US or just with other third app like OpenHab or NodeRed.
But it’s made for app that support this API, not all manufacturer personnal application.
In that case, tuya needs to add support for Phoscon.
