Lost in Space!
I have a Conbee2 dongle since a week.
I tried to install it on my Raspberry/Domoticz system and the system got corrupted and did not run anymore! I had to reinstall a current backup. Wasted a lot of time searching on the internet for no successful results.
So then I tried installing on Win10.
First hurdle is that in Device Manager it is shown as USB Serial Device (Com4).
Removing, deleting drivers, updating drivers does not seem to work because it never shows ConBee II
Maybe this ok?
So then I try to run deCONZ. Connect to Device shows ConBee II DE2287086. When I click connect, then the connect button goes gray for a time then comes back up. So it didn’t connect.
What am I doing wrong? Computers and programming can be frustrating but this takes the biscuit!
Well thanks for offering to help out. I just pasted a log file in the Debian Pastezone under the name pd22, not pd222. Any advice would be most welcome.
The reason I am trying to integrate this unit into my smart home system is that 3 weeks ago the boiler burst a pipe while we were away and the cellar got flooded. It’s a disaster but fortunately all the thousands of family photos were above water level. I would like to use some water detectors in the future.
I had same problem with conbee 1.
Was the drivers for me, the win10 native one don’t work, if I m right have found the good one here D2XX Drivers - FTDI
But I have a conbee 1.
Thanks for helping getting me to here!
I still cannot update the USB drivers which currently show USB Serial Device (Com4). Is it important to do so?
That is does it make sense trying to connect some devices before the correct USB drivers are installed or will I be wasting my time?
OK ? so was the firmware ?
All seem ok, drivers too.
You can try to add a device yes, for me all is fine, but can be usefull if you don’t have a GUI on your final machine, like that you can check network config.
Thank you guys for all the help. Yes I have my two water sensors successfully connected.
Now I have to repeat the exercise on my Raspi system. Hopefully it will now run again without problems.
I must be jinxed! Following the instructions for Rasp on phoscon.de I enter
and ultimately get the message E: unable to local package deconz.
I did all the usual updates before doing this. I am running Buster.
Am I alone having these kind of problems?
Any advice will be appreciated.
