I would certainly appreciate assistance on this issue.
I installed Node Red on my Windows 10 pc and have been using deCONZ successfully for home automation. All the temperature sensors installed around the house stopped working (i.e., the deCONZ in nodes all have red dots). These temperature sensors are using the Phoscon gateway with ip address 127.0.0.1. I noticed that node red is throwing the following error.
28 Nov 14:58:53 - [error] [deconz-server:Phoscon-GW] WebSocket error: Error: connect ECONNREFUSED 127.0.0.1:443
28 Nov 14:58:53 - [warn] [deconz-server:Phoscon-GW] WebSocket disconnected: 1006 -
At first, based upon posts I read, I thought it might be a firewall problem. So, I went into Windows Defender Firewall and creating both inbound and outbound rules that specifies connections to TCP ports 443 and 1883. This did not cure the problem.
Could someone with knowledge in this area please suggest a possible solution?
Thank you.
