Moin,
wie kann ich diese Fehler (Siehe Bild) beheben?
Gateway zurücksetzen funktioniert ebenfalls nicht.
Mit freundlichen Grüßen
Frank62
Moin,
how can I fix these errors (see picture)?
Resetting the gateway does not work either.
Moin,
Frank62
Moin,
Please write in English as we are an English forum.
I made the english translation with Deepl. I do not know English. I don’t know if Deepl did it right.
The stick is not seen by Phoscon.
How are you running deconz ?
Hiermit konnte ich mein Problem lösen, der Stick läuft jetzt mit Docker.
With this I was able to solve my problem, the stick is now running Docker.
gruß frank
I think, that better is use original repo:
deconz:
image: deconzcommunity/deconz:stable
container_name: deconz
restart: unless-stopped
ports:
- "8090:80"
- "443:443"
- "5901:5900"
volumes:
- ./volumes/deconz:/opt/deCONZ
devices:
#ConBee II:
- /dev/ttyACM0
environment:
- DECONZ_VNC_MODE=1
- DECONZ_VNC_PASSWORD=yourpassword
- DEBUG_INFO=1
- DEBUG_APS=0
- DEBUG_ZCL=0
- DEBUG_ZDP=0
- DEBUG_OTAU=0
- TZ=Europe/Prague
