Conbee2 | Firmware: not connected 2.14.01, buster
I rebooted the Rasp 4 today and since then the Conbee2 can no longer be found in the Phoscon app.
I have already changed the USB ports but that makes no difference.
The stick also seems to be detected:
openhabian@openhab:~ $ lsusb
Bus 001 Device 003: ID 1cf1:0030 Dresden Elektronik
I just plugged the stick into Windows 10 and it runs there.
Under Windows I have then also successfully flashed directly to version deCONZ_ConBeeII_0x26720700.bin.GCF.
But still no stick is detected under Linux and I can’t see any problem in the logs either:
-- Reboot --
Mar 14 22:21:48 openhab systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- Subject: A start job for unit deconz.service has finished successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A start job for unit deconz.service has finished successfully.
-- The job identifier is 109.
Mar 14 22:21:49 openhab deCONZ[358]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-openhabian'
Mar 14 22:21:50 openhab deCONZ[358]: libpng warning: iCCP: known incorrect sRGB profile
Mar 14 22:21:51 openhab deCONZ[358]: This plugin does not support propagateSizeHints()
What else can I do?
Can you share some logs? In #deconz you can find out how.
Logs under: debian Pastezone
22:56:20:866 device disconnected reason: 1, device index: 0
That indicates that the stick is either removed from the PI or that it reboots. We often see this when theres not enough power. What Power supply do you use?
I have been using the following power supply for a year:
Miuzei 5 V 3A USB-C
When using a Raspberry Pi, the original power supply is required to guarantee a stable gateway. Only this power supply delivers 5.1V and 2.5A (Raspberry Pi 3B+) respectively 3A (Raspberry Pi 4B). And it definitely has good quality.
https://www.raspberrypi.org/documentation/computers/raspberry-pi.html#power-supply
I just ordered the official power supply and will give feedback if this solves the problem.
Unfortunately, the orginal power supply did not bring success :frowning: .
The stick is found on the Raspberry:
openhabian@openhab:~ $ dmesg
[  313.787442] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[  313.926485] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[  313.926508] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  313.926526] usb 1-1.3: Product: ConBee II
[  313.926543] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[  313.926560] usb 1-1.3: SerialNumber: DE2470694
[  317.530053] usb 1-1.3: USB disconnect, device number 3
[  317.827502] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
[  317.966580] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[  317.966602] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  317.966621] usb 1-1.3: Product: ConBee II
[  317.966638] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[  317.966655] usb 1-1.3: SerialNumber: DE2470694
I would do a manually firmware rewrite with a Raspberry Pi and a separate SD card. Just write our Image with Desktop to the SD card for a temporary test system.
With this system it can be checked whether in the Phoscon App under Menu > Gateway > General > Firmware a version in the format 26xx0700 is available - and not “Firmware not connected”. If yes, a device can also be tried to be connected and controlled as a test.
After a reinstallation of the raspberry pi (what was due anyway :wink: ) - access to the stick was possible again :partying_face: .
