Conbee III in Raspi/Portainer enviroment not working
I have a Portainer enviroment running on my Raspberry Pi but i dont get the Conbee 3 working on it.
The deconz is running ant the Phoscon App is reachable via browser. In the Gateway Settings is the FIrmware status “Not connected”. I’m using a USB extension cable and the COnbee is the only USB device. It is detected at ttyUSB0.
this is the deconz log;
deconzcommunity/deconz] Starting deCONZ…
[deconzcommunity/deconz] Current deCONZ version: 2.26.3
[deconzcommunity/deconz] Web UI port: 80
[deconzcommunity/deconz] Websockets port: 8443
[deconzcommunity/deconz] Using options --auto-connect=1 --appdata=/opt/deCONZ --dbg-info=1 --dbg-aps=0 --dbg-zcl=0 --dbg-ddf=0 --dbg-dev=0 --dbg-zdp=0 --dbg-ota=0 --dbg-error=0 --dbg-http=0 --dev-test-managed=0 --http-port=80 --ws-port=8443
[deconzcommunity/deconz] VNC Disabled
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-deconz’
19:21:04:205 HTTP Server listen on address 0.0.0.0, port: 80, root: /usr/share/deCONZ/webapp/
19:21:04:253 /opt/deCONZ/config.ini exists and is writeable
19:21:04:253 /opt/deCONZ/zll.db exists and is writeable
19:21:04:453 dev /dev/ttyAMA0
19:21:04:475 COM: /dev/ttyUSB0 / serialno: , ConBee
19:21:04:476 ZCLDB init file /opt/deCONZ/zcldb.txt
19:21:04:623 DDF enabled for Gold status
19:21:05:993 gw run mode: normal
19:21:05:993 GW sd-card image version file does not exist: /opt/deCONZ/gw-version
19:21:05:993 sd-card cid: 035344534c36344780ffffffff00f96f
19:21:05:995 DB sqlite version 3.42.0
19:21:05:997 DB PRAGMA page_count: 46
19:21:05:997 DB PRAGMA page_size: 4096
19:21:05:997 DB PRAGMA freelist_count: 0
19:21:05:997 DB file size 188416 bytes, free pages 0
19:21:05:997 DB PRAGMA user_version: 9
19:21:05:997 DB cleanup
19:21:05:998 DB create temporary views
19:21:06:049 [INFO] - Timezone read is ‘Etc/UTC’
19:21:06:049 [INFO] - Environment variable TZ found: Europe/Berlin…
19:21:06:051 Started websocket server on 0.0.0.0, port: 8443
19:21:06:053 [INFO] - Found file containing button maps. Parsing data…
19:21:06:089 [INFO] - Button maps loaded.
19:21:06:092 found node plugin: /usr/share/deCONZ/plugins/libde_rest_plugin.so - REST API Plugin
19:21:06:095 found node plugin: /usr/share/deCONZ/plugins/libstd_otau_plugin.so - STD OTAU Plugin
19:21:06:159 dlg action: Read binding table
19:21:07:190 dev /dev/ttyAMA0
19:21:07:205 COM: /dev/ttyUSB0 / serialno: , ConBee
19:21:13:976 DEV Tick.Init: booted after 8000 seconds
19:21:20:086 dev /dev/ttyAMA0
19:21:20:105 COM: /dev/ttyUSB0 / serialno: , ConBee
19:21:26:976 start reconnect to network
19:21:31:976 failed to reconnect to network try=1
19:21:32:818 New websocket 192.168.1.178:62655 (state: 3)
19:21:34:073 dev /dev/ttyAMA0
19:21:34:095 COM: /dev/ttyUSB0 / serialno: , ConBee
19:21:36:645 Websocket disconnected 192.168.1.178:62655, state: 0, close-code: 1001, reason:
19:21:36:976 try to reconnect to network try=2
19:21:38:702 Invalid admin password hash
19:21:41:184 created username: 92A746FEC6, devicetype: Phoscon#B2512x1284
19:21:41:976 try to reconnect to network try=3
19:21:43:093 New websocket 192.168.1.178:62699 (state: 3)
19:21:45:037 dev /dev/ttyAMA0
19:21:45:050 COM: /dev/ttyUSB0 / serialno: , ConBee
19:21:45:905 Websocket disconnected 192.168.1.178:62699, state: 0, close-code: 1001, reason:
19:21:46:977 failed to reconnect to network try=4
19:21:47:132 New websocket 192.168.1.178:62707 (state: 3)
19:21:51:975 failed to reconnect to network try=5
19:21:56:975 failed to reconnect to network try=6
19:21:59:076 dev /dev/ttyAMA0
19:21:59:090 COM: /dev/ttyUSB0 / serialno: , ConBee
19:22:01:975 try to reconnect to network try=7
19:22:06:976 try to reconnect to network try=8
19:22:09:084 dev /dev/ttyAMA0
19:22:09:097 COM: /dev/ttyUSB0 / serialno: , ConBee
19:22:11:976 failed to reconnect to network try=9
19:22:16:976 failed to reconnect to network try=10
19:22:21:976 reconnect network failed, try later
19:22:21:976 start reconnect to network
19:22:23:086 dev /dev/ttyAMA0
19:22:23:100 COM: /dev/ttyUSB0 / serialno: , ConBee
19:22:26:976 try to reconnect to network try=1
19:22:31:975 try to reconnect to network try=2
19:22:34:074 dev /dev/ttyAMA0
19:22:34:088 COM: /dev/ttyUSB0 / serialno: , ConBee
19:22:36:976 failed to reconnect to network try=3
19:22:41:976 failed to reconnect to network try=4
19:22:46:975 failed to reconnect to network try=5
19:22:48:072 dev /dev/ttyAMA0
19:22:48:086 COM: /dev/ttyUSB0 / serialno: , ConBee
19:22:51:976 try to reconnect to network try=6
19:22:56:976 try to reconnect to network try=7
19:22:59:092 dev /dev/ttyAMA0
19:22:59:106 COM: /dev/ttyUSB0 / serialno: , ConBee
19:23:01:976 failed to reconnect to network try=8
19:23:06:975 failed to reconnect to network try=9
19:23:11:975 failed to reconnect to network try=10
19:23:13:078 dev /dev/ttyAMA0
19:23:13:093 COM: /dev/ttyUSB0 / serialno: , ConBee
19:23:16:976 reconnect network failed, try later
19:23:16:976 start reconnect to network
19:23:21:975 try to reconnect to network try=1
any advice or someone is facing the same issue?
No one a idea is this setup so special?
I’ve ordered a Conbee II just to test if this is working.
The Conbee II is working.
I’m not 100% sure, but can you try adding the option --baudrate=115200 to the command line.
Since this is running in the container with restricted access to USB information I guess that deCONZ isn’t able to query the relevant information on its own.
