ConBee III for ZigBee + ConBee II as Thread Router at the same Raspberry?
Hello everyone!
I have successfully operated my ZigBee actuators for several years with the Conbee II on a Raspberry and controlled them via ioBroker. Now I have replaced this stick with a new Conbee III because of its BLE actuator support.
I would like to flash the firmware on the old Conbee II and continue to use it as a Thread Border Router.
Question 1: Can I run both sticks on the same Raspberry?
If so, I would like to use the Aqara Motion and Light Sensor P2 with the flashed ConBee II. So far I haven’t had anything to do with a Matter device.
Question 2: Do I then also find and parameterize this sensor via deConz or the Phoscon app or only via the Aqara app?
Many thanks in advance for your explanations.
AFAIK it just works with Homeassistant: OpenThread documentation
I know it is an old question. But I have had the same idea. Does it work?
I’m not sure to what extent interference occurs. Both protocols operate on almost the same frequency.
