Since DSM 7.0 i can’t use Conbee II stick with Docker on my Synology NAS.
USB works fine and the sitck is regonized.
Anybody knows a how to?
Synology: How to Add USB Support on DSM 7 – Marius Hosting A quick google showed this.
Perhaps you can use a VM instead of docker.
I have seen that.
But wanted to use it by Docker.
Tutorial is used before with Docker worked very fine for a noob…
I am not sure what you mean? The guide i just linked seems to be perfect for your cause
I mean i want to use Deconz with Docker.
Not a VM.
The guide i linked shows how that can be done i guess.
From a Synology owner: I saw the writing on the wall with them stripping out USB support awhile ago and I think they are going to further restrict their product in more releases of DSM.
I run anything with a dongle on a Raspberry Pi and Docker while Home Assistant is on the Synology. There are a few ways to automate a backup of the entire Pi, or just Docker data files, to a Synology share so you’ll be ready if something happens.
Just an idea for you to consider as an alternative.
