I have installed the deconz plugin on raspbian buster and all seems working but impossible to see any aqara device on phoscon application.
Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: e
Active: active (running) since Mon 2022-01-10 14:54:50 CET; 18h ago
Main PID: 413 (deCONZ)
Tasks: 4 (limit: 4915)
└─413 /usr/bin/deCONZ -platform minimal --http-port=80
Jan 10 14:54:50 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST A
Jan 10 14:54:58 raspberrypi deCONZ[413]: QStandardPaths: XDG_RUNTIME_DIR not set
Jan 10 14:55:00 raspberrypi deCONZ[413]: libpng warning: iCCP: known incorrect s
Jan 10 14:55:02 raspberrypi deCONZ[413]: This plugin does not support propagateS
Jan 10 14:55:05 raspberrypi deCONZ[413]: This plugin does not support propagateS
I have try to add the device with the 3 second push the bottum on the aquara but nothing. I have test door sensor and temperature.
Can you help me ?
Thank you so much.
