I searched but didn’t find anything that helped. I’m also a novice in the home automation game.
I have a Home Assistant running in a virtualbox on my Windows PC. As part of the setup, I use a Conbee II to communicate with a MOES wireless switch. I’ve had this up and running for about 4 months without issue.
Last night, I noticed all of the lights were blinking on the MOES like it wasn’t paired. When I started to troubleshoot this morning, I got an error on the ConBee II integration in Home Assistant.
I tried various reboots and that didn’t help. I unplugged the Conbee and plugged it back in and I got the Windows chime for when you plug in a USB, then quickly got the chime for unplugging a USB. Every few seconds, I get the unplug chime, but never get the plug in chime after that initial one.
I tried looking for the device using the GCFFlasher -l command and nothing shows up.
I installed deCONZ and it doesn’t see the Conbee. The ‘connect to device’ dropdown is empty.
I plugged the Conbee into another PC and used GCFFlasher -l and I can see the device on that PC, so I know the Conbee is working.
Any ideas why my original PC stopped recognizing the Conbee and how I can fix this?
Thank you!
