Conbee II last sensor info 4 days ago
I am using phoscon with conbee 2 on haasio. I added a few devices some days ago and all.went smooth, but nothinf changed from then. Do I need to do something that temperature and humidity would automatically update? Makes no sense that it is not updating every 30mins or something.
If all is working, Xiaomi/Aqara device, make a report at least every 1h.
If you haven’t battery issue you device have probably disconnect.
All devices? All temperature humidity shows same. How can all devices have problems?
I mean the “last updated = 4 days”
This is not normal for Xiaomi/Aqara
Any suggestions what to do? I had conbee III that couldnt even connect to.devices, so now bought conbee II and have these issuess…
Can you share some logs? In deCONZ there is a topic called how to get logs.
Known issue.
After adding devices a restart is needed…
I am trying, did everything according to intstructions, added port for NVC but still cannot copy logs, dont understand why.
Just restarted hassio and then deconz and still same issue:
can you explain more on this known issue? Maybe doing something wrong?
I was referring to this open issue on GitHub:
Seems perhaps not your issue then …
You need to use a vnc client.
