ConBee II detected such as RaspBee
I have been using this key for a few months, I wanted to update it to improve the functioning with some devices I tried to run the command with GCFlasher and I found that it is detected as RaspBee instead of ConBee II, as well as from the command:
sudo GCFFlasher -l
GCFFlasher V2_11 (c) dresden elektronik ingenieurtechnik gmbh 2017/12/10
RaspBee: /dev/ttyAMA0 (default)
no FTDI devices found
How are you running deCONZ?
Home assistant? Docker?
Actually use only Raspberry pi 3 such as bridge, i just test all with Z2M, but GCFlasher dont work correctly.
I’m not sure what you mean.
For a test before using it officially, I installed GCFlasher and I noticed that it does not recognize the key correctly, as well as from the outuput inserted and I wonder why and above all how to solve it since I cannot update the FW.
Thank you :slight_smile:
Do you have deCONZ installed?
