ConBee II Backup/Restore Windows
at first happy new year for 2022. At second, sorry for my terrible English vocabulary. :slight_smile:
I have the problem that i changed my Windows OS. I have a new Windows PC and i want to restore my ConBee II (deCONZ) Data.
The Webserver (PhosCon) is available and restore my Backup to the new PC. I installed the deCONZ App and i see my Nodes in my Network. The problem is that the ZigBee meshing have some problems.
I see some new green lines from the ccordinator to any sensors.
But the network meshing is not going finaly to all actors or sensors.
What is my misstake ?
I hope that some peoples can help me ,because it is dark in my house :slight_smile:
Thanks a lot.
Regards
Happy new year!
can you share some logs :slight_smile: ? How to get logs? - #2
Kind regards,
sorry, this is my first Debugsession. Is that ok ath this format ?
Sorry, i send in few minutes an text file.
ok, i dont underastand what i have to do to send here the debug log.
It is not possible to attach the file.
Sorry …
Can you use pastebin?
yes i can. But what is pastebin ?
Do you need al link or what is the result from this ?
Sorry, because i hear about this app first.
ok i dont know it is the right way but i post the link.
https://pastebin.com/FkzdhEy4
ok i have post the link to pastebin.
Regards
Just read it. I see a lot of:
  1. 11:53:40:418 APS-DATA.confirm id: 58, status: 0xE1
It seems that you have interference issues. Are you using an Extension cable ? If no, you should use it :slight_smile:
Kind regards,
Ok,
i try it. It is possible to download a documentation für all these debug information?
In few minutes iam back.
contains a lot :slight_smile:
In this case:
ok, it seems to be building up, can you please briefly explain to me what has happened now, that an extension cable is causing it to work?
Great!
There’s a bug in the USB 3.0 implementation which disrupts 2.4GHZ traffic. Extension cable takes the conbee away from the USB interference. See the following for more info:
Ok, thanks a lot.
It works fine.
Regards
