Hi there,
Basically, the issue is after a home server restart (using an Intel NUC running Ubuntu) and moving the server, the Conbee II no longer seems to be able to control anything and errors out with 0xE1 on task. The strange thing is it seems to be able to at least get statuses of devices—which at least some seem accurate and updated more recently.
I looked at some of the past threads, most of which relate to older firmware (I’m currently on 0x26680700). I started on an older firmware, but updated and it didn’t fix my issue.
I understand 0xE1 usually means interference. I have the Conbee II on a VERY long USB extension, and after the issue moved the server back to its original location. It still didn’t fix the issue. Finally, I also tried rolling back the network (alt-click on Advanced on Gateway and try older networks).
Additional details: I was originally using the marthoc Docker container, and now updated to the deconzcommunity version. Both cases exhibited the same behavior.
Any suggestions on what else to try, other than resetting the entire network and starting from scratch? (Including a VNC screenshot for both the logs and currently nonexistent topography)
Best,
James
