Conbee 3 in Containerstation Qnap. Usb Port
i use a conbee II and link my ttyACM0 to the Docker Container - works fine. Now i want switch to Conbee III to fit for the future and Matter etc. now i try to link the conbee III with ttyUSB0 and BAUD 115200 to the Container and replace the conbee II.
But the conbee III not ne recognize by the deconz ( news version).
Now i look for a user have this setup:
  • Deconz 2.27.3
  • docker on an Qnap Container station
  • Conbee III
  • plug in the Conbee in the back USB Ports
  • and setup with ist run.
I try the moste of the things without success.
any idea - try try to connect network was all in the log.
Can you share the logs ?
Sure :slight_smile:
my mistake.
think this is the problem:
stat: cannot statx ‘/dev/ttyUSB0’: No such file or directory
but i do not know how to find the right USB Port an the Qnap Nas.
I try tty0, or look with different tools on the OS … own the end this is posted all the time
16:48:39:272 ZDP get active endpoints for 0xFA96
16:48:44:271 failed to reconnect to network try=5
16:48:49:272 failed to reconnect to network try=6
16:48:54:272 failed to reconnect to network try=7
16:48:59:272 failed to reconnect to network try=8
16:49:04:273 failed to reconnect to network try=9
16:49:09:272 failed to reconnect to network try=10
16:49:14:272 reconnect network failed, try later
[deconzcommunity/deconz] Starting deCONZ...
[deconzcommunity/deconz] Current deCONZ version: 2.27.3
[deconzcommunity/deconz] Web UI port: 80
[deconzcommunity/deconz] Using options --auto-connect=1 --appdata=/opt/deCONZ --dbg-info=1 --dbg-aps=0 --dbg-zcl=0 --dbg-ddf=0 --dbg-dev=0 --dbg-zdp=0 --dbg-ota=0 --dbg-error=0 --dbg-http=0 --dev-test-managed=0 --http-port=80 --ws-port=443 --baudrate=115200
stat: cannot statx '/dev/ttyUSB0': No such file or directory
[deconzcommunity/deconz] VNC port: 5900
[deconzcommunity/deconz] VNC DISABLE PASSWORD: 0
tigervncserver: No VNC server running for this user!
Cleaning stale pidfile '/home/deconz/.vnc/phoscon:0.pid'!
Cleaning stale X11 lock '/tmp/.X0-lock'!
Cleaning stale X11 lock '/tmp/.X11-unix/X0'!
TigerVNC server sessions:
X DISPLAY #	RFB PORT #	RFB UNIX PATH	PROCESS ID #	SERVER
New Xtigervnc server 'phoscon:0 (deconz)' on port 5900 for display :0.
Use xtigervncviewer -SecurityTypes VncAuth,TLSVnc -passwd /tmp/tigervnc.APp5uu/passwd phoscon:0 to connect to the VNC server.
WebSocket server settings:
  - Listen on :6080
  - Web server. Web root: /usr/share/novnc
  - SSL/TLS support
  - Backgrounding (daemon)
[deconzcommunity/deconz] NOVNC port: 6080
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-deconz'
16:43:16:867 /opt/deCONZ/config.ini exists and is writeable
16:43:16:867 /opt/deCONZ/zll.db exists and is writeable
16:43:17:487 ZCLDB init file /opt/deCONZ/zcldb.txt
16:43:17:681 DDF enabled for Gold status
16:43:17:726 gw run mode: docker
16:43:17:726 GW sd-card image version file does not exist: /opt/deCONZ/gw-version
16:43:17:727 DB sqlite version 3.42.0
16:43:17:728 DB PRAGMA page_count: 142
16:43:17:728 DB PRAGMA page_size: 4096
16:43:17:728 DB PRAGMA freelist_count: 8
16:43:17:728 DB file size 581632 bytes, free pages 8
16:43:17:729 DB PRAGMA user_version: 10
16:43:17:729 DB cleanup
16:43:17:754 DB create temporary views
16:43:21:315 DB skip loading sensor Fenster Küche 43, handled by DDF Aqara open/close sensor MCCGQ11LM
16:43:21:316 DB skip loading sensor Fenster Schlafzimmer 46, handled by DDF Aqara open/close sensor MCCGQ11LM
16:43:21:319 DB skip loading sensor Tür Balkon rechts 51, handled by DDF Aqara open/close sensor MCCGQ11LM
16:43:21:323 DB skip loading sensor Tür Terrasse links 48, handled by DDF Aqara open/close sensor MCCGQ11LM
16:43:21:325 DB skip loading sensor Kaffee Knopf Etti 39, handled by DDF TRADFRI SHORTCUT Button - E1812
16:43:21:326 DB legacy loading sensor Schrank Michael 38, later handled by DDF TRADFRI on/off switch - E1743
16:43:21:330 DB skip loading sensor BWM Michael Schrank 54, handled by DDF TRADFRI motion sensor - E1525, E1745
16:43:21:332 DB skip loading sensor Fenster Dreieck 66, handled by DDF Smart Zigbee Door Window Contact
16:43:21:334 DB skip loading sensor Controller Play 3 Office 22, handled by DDF SYMFONISK Sound Controller - E1744
16:43:21:335 DB skip loading sensor RelativeRotary 60 60, handled by DDF SYMFONISK Sound Controller - E1744
16:43:21:336 DB skip loading sensor RelativeRotary 62 62, handled by DDF SYMFONISK Sound Controller - E1744
16:43:21:337 DB skip loading sensor SW Bewegungslicht 78, handled by DDF TRADFRI on/off switch - E1743
16:43:21:338 DB skip loading sensor Pool 53, handled by DDF TRADFRI SHORTCUT Button - E1812
16:43:21:340 DB skip loading sensor Tür Terrasse rechts 49, handled by DDF Aqara open/close sensor MCCGQ11LM
16:43:21:341 DB skip loading sensor Fenster Gästebad 50, handled by DDF Aqara open/close sensor MCCGQ11LM
16:43:21:342 DB skip loading sensor Fenster Strasse rechts 45, handled by DDF Aqara open/close sensor MCCGQ11LM
16:43:21:343 DB skip loading sensor Fenster Hof 44, handled by DDF Aqara open/close sensor MCCGQ11LM
16:43:21:344 DB skip loading sensor Controller Sonos Mobile 26, handled by DDF SYMFONISK Sound Controller - E1744
16:43:21:346 DB skip loading sensor RelativeRotary 61 61, handled by DDF SYMFONISK Sound Controller - E1744
16:43:21:348 DB skip loading sensor Controller Terrasse 25, handled by DDF SYMFONISK Sound Controller - E1744
16:43:21:349 DB skip loading sensor Geber Sportecke 2, handled by DDF TRADFRI remote control - E1810
16:43:21:350 DB skip loading sensor Geber Gästebad 15, handled by DDF TRADFRI remote control - E1810
16:43:21:356 DB skip loading sensor SCB Ikea Test 129, handled by DDF TRADFRI SHORTCUT Button - E1812
16:43:21:357 DB skip loading sensor Schreibtisch AN AUS 34, handled by DDF TRADFRI on/off switch - E1743
16:43:21:358 DB skip loading sensor Dimmschalter Terrasse 32, handled by DDF Hue dimmer switch
16:43:21:368 DB skip loading sensor Schrank Etti 37, handled by DDF TRADFRI on/off switch - E1743
16:43:21:371 DB skip loading sensor BWM Etti Schrank 40, handled by DDF TRADFRI motion sensor - E1525, E1745
16:43:21:373 DB skip loading sensor BWM Klavier 73, handled by DDF TRADFRI motion sensor - E1525, E1745
16:43:21:375 DB skip loading sensor BWM Office 27, handled by DDF TRADFRI motion sensor - E1525, E1745
16:43:21:376 DB skip loading sensor Dimmschalter HUE neu 57, handled by DDF Hue dimmer switch (2021)
16:43:21:377 DB skip loading sensor SW Ikea Flur 77, handled by DDF SOMRIG Shortcut Button
16:43:21:379 DB skip loading sensor OpenClose 90 90, handled by DDF Smart Zigbee Door Window Contact
16:43:21:388 DB skip loading sensor Tür Dusche 65, handled by DDF Smart Zigbee Door Window Contact
16:43:21:393 DB skip loading sensor RODRET Dimmer 63, handled by DDF RODRET Dimmer - E2201
16:43:21:394 DB skip loading sensor BWM Küche 64, handled by DDF TS0202 Presence sensor
16:43:21:395 DB skip loading sensor BWM Durchgang 69, handled by DDF TRADFRI motion sensor - E1525, E1745
16:43:21:417 Started websocket server on 0.0.0.0, port: 443
16:43:21:449 [INFO] - Found file containing button maps. Parsing data...
16:43:21:472 [INFO] - Button maps loaded.
16:43:21:473 found node plugin: /usr/share/deCONZ/plugins/libde_rest_plugin.so - REST API Plugin
16:43:21:476 found node plugin: /usr/share/deCONZ/plugins/libstd_otau_plugin.so - STD OTAU Plugin
16:43:21:685 LightNode 1: Configuration tool 1 added
16:43:21:689 LightNode 6: Terrasse Rechts added
16:43:21:696 LightNode 9: Doppelbett added
16:43:21:706 skip legacy loading 14:b4:57:ff:fe:7b:3c:7f-01 / TRADFRI bulb GU10 WW 400lm
16:43:21:707 skip legacy loading 14:b4:57:ff:fe:7b:3c:7f-01 / TRADFRI bulb GU10 WW 400lm
16:43:21:709 skip legacy loading 14:b4:57:ff:fe:7b:3c:7f-01 / TRADFRI bulb GU10 WW 400lm
16:43:21:715 LightNode 11: Kleiderschrank Michael added
16:43:21:720 skip legacy loading 84:18:26:00:00:07:4d:14-03 / Classic A60 W clear - LIGHTIFY
16:43:21:721 skip legacy loading 84:18:26:00:00:07:4d:14-03 / Classic A60 W clear - LIGHTIFY
16:43:21:725 LightNode 21: Apfelbaum added
16:43:21:732 skip legacy loading 00:21:2e:ff:ff:01:0f:cd-0a / FLS-PP3
16:43:21:735 skip legacy loading 00:21:2e:ff:ff:01:0f:cd-0a / FLS-PP3
16:43:21:737 skip legacy loading 00:21:2e:ff:ff:01:0f:cd-0a / FLS-PP3
16:43:21:744 skip legacy loading 7c:b0:3e:aa:0a:08:dc:1f-03 / Plug 01
16:43:21:746 skip legacy loading 7c:b0:3e:aa:0a:08:dc:1f-03 / Plug 01
16:43:21:755 LightNode 10: Kleiderschrank Beate added
16:43:21:758 LightNode 15: Kerze links added
16:43:21:771 LightNode 25: Apfelbaum, zwei added
16:43:21:793 skip legacy loading 14:b4:57:ff:fe:73:c3:bf-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:795 skip legacy loading 14:b4:57:ff:fe:73:c3:bf-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:796 skip legacy loading 14:b4:57:ff:fe:73:c3:bf-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:801 LightNode 16: SW TUJA added
16:43:21:805 LightNode 13: Eiffelturm added
16:43:21:809 LightNode 22: BAMBUS LAMPE added
16:43:21:814 skip legacy loading 7c:b0:3e:aa:0a:09:7a:35-03 / Plug 01
16:43:21:816 skip legacy loading 7c:b0:3e:aa:0a:09:7a:35-03 / Plug 01
16:43:21:818 skip legacy loading 14:b4:57:ff:fe:50:53:70-01 / TRADFRI bulb GU10 WW 400lm
16:43:21:820 skip legacy loading 14:b4:57:ff:fe:50:53:70-01 / TRADFRI bulb GU10 WW 400lm
16:43:21:822 skip legacy loading 14:b4:57:ff:fe:50:53:70-01 / TRADFRI bulb GU10 WW 400lm
16:43:21:832 skip legacy loading ec:1b:bd:ff:fe:9c:3e:c7-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:834 skip legacy loading ec:1b:bd:ff:fe:9c:3e:c7-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:835 skip legacy loading ec:1b:bd:ff:fe:9c:3e:c7-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:841 skip legacy loading ec:1b:bd:ff:fe:7d:a8:0c-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:843 skip legacy loading ec:1b:bd:ff:fe:7d:a8:0c-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:845 skip legacy loading ec:1b:bd:ff:fe:7d:a8:0c-01 / TRADFRI bulb GU10 WS 400lm
16:43:21:848 LightNode 20: Kerze rechts added
16:43:21:851 skip legacy loading 7c:b0:3e:aa:0a:09:b5:e9-03 / Plug 01
16:43:21:853 skip legacy loading 7c:b0:3e:aa:0a:09:b5:e9-03 / Plug 01
16:43:21:856 skip legacy loading 84:18:26:00:00:0d:ad:10-03 / Plug 01
16:43:21:857 skip legacy loading 84:18:26:00:00:0d:ad:10-03 / Plug 01
16:43:21:860 LightNode 8: Terrasse links added
16:43:21:999 dlg action: Read binding table
16:43:22:280 DEV no DDF for 0x00124B002A6CC08C, modelId: MS01
16:43:22:280 DEV create on-the-fly DDF for 0x00124B002A6CC08C
16:43:22:281 DEV no DDF for 0x00158D0006726D4C, modelId: lumi.remote.b1acn01
16:43:22:281 DEV create on-the-fly DDF for 0x00158D0006726D4C
16:43:22:282 DEV found DDF for 0x00158D00067C1B69, path: , result: 2
16:43:22:282 DEV found DDF for 0x00158D00067BCFFF, path: , result: 2
16:43:22:283 DEV found DDF for 0x00158D0006792AA4, path: , result: 2
16:43:22:283 DEV no DDF for 0x00158D000174296E, modelId: RB 165
16:43:22:283 DEV create on-the-fly DDF for 0x00158D000174296E
16:43:22:283 DEV found DDF for 0x00158D0001741FEA, path: , result: 2
16:43:22:294 DEV found DDF for 0xA4C1386D0CE108D6, path: /usr/share/deCONZ/devices/tuya/ts0202_presence_sensor.json, result: 1
16:43:22:337 DEV found DDF for 0x5CC7C1FFFE62B268, path: /usr/share/deCONZ/devices/ikea/somrig_shortcut_button.json, result: 1
16:43:22:345 DEV found DDF for 0x680AE2FFFE2F4D05, path: /usr/share/deCONZ/devices/ikea/tradfri_motion_sensor.json, result: 1
16:43:22:352 DEV found DDF for 0x001788010B799539, path: /usr/share/deCONZ/devices/philips/rwl022_dimmer_switch.json, result: 1
16:43:22:357 DEV found DDF for 0x14B457FFFE7B3C7F, path: /usr/share/deCONZ/devices/ikea/tradfri_bulb_gu10_ww_400lm.json, result: 1
16:43:22:367 DEV found DDF for 0x680AE2FFFE3553B1, path: /usr/share/deCONZ/devices/ikea/tradfri_motion_sensor.json, result: 1
16:43:22:373 DEV found DDF for 0xA4C138C261C65592, path: /usr/share/deCONZ/devices/tuya/_TZ3000_TS0203_door_sensor.json, result: 1
16:43:22:374 DEV no DDF for 0x84FD27FFFE51EBC8, modelId: TRADFRI Driver 10W
16:43:22:375 DEV create on-the-fly DDF for 0x84FD27FFFE51EBC8
16:43:22:381 DEV found DDF for 0x8418260000074D14, path: /usr/share/deCONZ/devices/osram/classic_a60_w_clear.json, result: 1
16:43:22:382 DEV no DDF for 0xA4C138ED9DF4A081, modelId: GL-G-002P
16:43:22:382 DEV create on-the-fly DDF for 0xA4C138ED9DF4A081
16:43:22:388 DEV found DDF for 0x8CF681FFFE51E6CE, path: /usr/share/deCONZ/devices/ikea/tradfri_shortcut_button.json, result: 1
16:43:22:400 DEV found DDF for 0xCCCCCCFFFEE3993A, path: /usr/share/deCONZ/devices/ikea/symfonisk_sound_contoller.json, result: 1
16:43:22:411 DEV found DDF for 0x00212EFFFF010FCD, path: /usr/share/deCONZ/devices/dresden_elektronik/fls_pp3.json, result: 1
16:43:22:418 DEV found DDF for 0xCCCCCCFFFEE57249, path: /usr/share/deCONZ/devices/ikea/tradfri_remote_control.json, result: 1
16:43:22:422 DEV found DDF for 0x7CB03EAA0A08DC1F, path: /usr/share/deCONZ/devices/osram/plug_01.json, result: 1
16:43:22:427 DEV found DDF for 0x8CF681FFFE51E6CA, path: /usr/share/deCONZ/devices/ikea/tradfri_shortcut_button.json, result: 1
16:43:22:443 DEV found DDF for 0xCCCCCCFFFEE073FB, path: /usr/share/deCONZ/devices/ikea/symfonisk_sound_contoller.json, result: 1
16:43:22:448 DEV found DDF for 0x680AE2FFFE1247EE, path: /usr/share/deCONZ/devices/ikea/tradfri_on_off_switch.json, result: 1
16:43:22:448 DEV found DDF for 0xB4E3F9FFFEC89A4C, path: , result: 2
16:43:22:461 DEV no DDF for 0x6C5CB1FFFE763CAD, modelId: TRADFRIbulbE27WWclear250lm
16:43:22:461 DEV create on-the-fly DDF for 0x6C5CB1FFFE763CAD
16:43:22:466 DEV found DDF for 0x8CF681FFFE32E4E3, path: /usr/share/deCONZ/devices/ikea/tradfri_shortcut_button.json, result: 1
16:43:22:469 DEV found DDF for 0x00158D0008073B49, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
16:43:22:473 DEV found DDF for 0x680AE2FFFEADDE75, path: /usr/share/deCONZ/devices/ikea/tradfri_remote_control.json, result: 1
16:43:22:478 DEV found DDF for 0x00158D000806E4FA, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
16:43:22:479 DEV found DDF for 0xA4C1386E4C9F2227, path: , result: 2
16:43:22:483 DEV found DDF for 0x0017880103E60AEC, path: /usr/share/deCONZ/devices/philips/rwl02_dimmer_switch.json, result: 1
16:43:22:487 DEV found DDF for 0x00158D000807396B, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
16:43:22:493 DEV found DDF for 0xA4C1380423B1E0D3, path: /usr/share/deCONZ/devices/tuya/_TZ3000_TS0203_door_sensor.json, result: 1
16:43:22:498 DEV found DDF for 0xEC1BBDFFFE546D92, path: /usr/share/deCONZ/devices/ikea/tradfri_on_off_switch_old_fw.json, result: 1
16:43:22:504 DEV found DDF for 0x8CF681FFFE5BA0F0, path: /usr/share/deCONZ/devices/ikea/tradfri_on_off_switch.json, result: 1
16:43:22:509 DEV found DDF for 0x00158D00080739A0, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
16:43:22:514 DEV found DDF for 0x2C1165FFFEA38917, path: /usr/share/deCONZ/devices/ikea/tradfri_motion_sensor.json, result: 1
16:43:22:520 DEV found DDF for 0x680AE2FFFE349468, path: /usr/share/deCONZ/devices/ikea/tradfri_motion_sensor.json, result: 1
16:43:22:528 DEV found DDF for 0x680AE2FFFE3DF543, path: /usr/share/deCONZ/devices/ikea/symfonisk_sound_contoller.json, result: 1
16:43:22:533 DEV found DDF for 0x14B457FFFE73C3BF, path: /usr/share/deCONZ/devices/ikea/gu10_ws_400lm_light.json, result: 1
16:43:22:538 DEV found DDF for 0x00158D0007E76555, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
16:43:22:538 DEV no DDF for 0xF0D1B8BE24080DF9, modelId: PLUG OUTDOOR EU T
16:43:22:538 DEV create on-the-fly DDF for 0xF0D1B8BE24080DF9
16:43:22:539 DEV no DDF for 0x00158D000580FDAA, modelId: iStar RGB Light
16:43:22:539 DEV create on-the-fly DDF for 0x00158D000580FDAA
16:43:22:540 DEV found DDF for 0xA4C1385214B1B605, path: , result: 2
16:43:22:545 DEV found DDF for 0x5CC7C1FFFE88AAEE, path: /usr/share/deCONZ/devices/ikea/rodret_dimmer.json, result: 1
16:43:22:549 DEV found DDF for 0x7CB03EAA0A097A35, path: /usr/share/deCONZ/devices/osram/plug_01.json, result: 1
16:43:22:553 DEV found DDF for 0x14B457FFFE505370, path: /usr/share/deCONZ/devices/ikea/tradfri_bulb_gu10_ww_400lm.json, result: 1
16:43:22:557 DEV found DDF for 0x00158D0007EC8CF8, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
16:43:22:562 DEV found DDF for 0xB4E3F9FFFEA02B59, path: /usr/share/deCONZ/devices/ikea/tradfri_motion_sensor.json, result: 1
16:43:22:567 DEV found DDF for 0x00158D0007E76211, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
16:43:22:571 DEV found DDF for 0xEC1BBDFFFE9C3EC7, path: /usr/share/deCONZ/devices/ikea/gu10_ws_400lm_light.json, result: 1
16:43:22:576 DEV found DDF for 0xA4C1380919FD6554, path: /usr/share/deCONZ/devices/tuya/_TZ3000_TS0203_door_sensor.json, result: 1
16:43:22:580 DEV found DDF for 0x00158D0007E76553, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
16:43:22:584 DEV found DDF for 0xEC1BBDFFFE7DA80C, path: /usr/share/deCONZ/devices/ikea/gu10_ws_400lm_light.json, result: 1
16:43:22:585 DEV found DDF for 0x6C5CB1FFFEA6041F, path: , result: 2
16:43:22:588 DEV found DDF for 0x7CB03EAA0A09B5E9, path: /usr/share/deCONZ/devices/osram/plug_01.json, result: 1
16:43:22:592 DEV found DDF for 0x84182600000DAD10, path: /usr/share/deCONZ/devices/osram/plug_01.json, result: 1
16:43:22:592 DEV found DDF for 0x00158D000191103C, path: , result: 2
16:43:23:666 New websocket 192.168.2.211:36856 (state: 3)
16:43:26:639 Announced to internet https://phoscon.de/discover
16:43:29:259 New websocket 192.168.2.76:42868 (state: 3)
16:43:29:272 DEV Tick.Init: booted after 8000 seconds
16:43:32:665 New websocket 192.168.2.210:57688 (state: 3)
With that I have no clue. Maybe @de_employees can help out?
may this helps:
lsusb
Bus 001 Device 109: ID 0403:6015 Future Technology Devices International, Ltd
Bus 001 Device 005: ID 1005:b155 Apacer Technology, Inc.
Bus 001 Device 067: ID 04e8:4001 Samsung Electronics Co., Ltd
Bus 001 Device 002: ID 1c05:2074
Bus 001 Device 107: ID 1a40:0801 TERMINUS TECHNOLOGY INC.
Bus 001 Device 063: ID 05e3:0610 Genesys Logic, Inc.
Bus 002 Device 003: ID 174c:5106 ASMedia Technology Inc.
Bus 002 Device 002: ID 1c05:3074
the bold line is the conbeeIII - i think - plug unplug test
I don’t have experience with the QNap container station, but from the logs it seems that the USB device file entry doesn’t exist in the container. In Docker this is usually done with the --device=/dev/ttyUSB0 when starting the container.
Absolut - i can link any port from the QNAP OS to /dev/ttyUSB0 - but witch one. The conbeeII runs on ACM0 - works fine.
so o look für somebody use containerstation on a QNAP and have Decont successfully connected to a conbee III
You can gather more information on the host via
udevadm info /dev/ttyUSBx
Which shows which one is the ConBee III and also some PCI stuff and port which may help to select the right device (I think in Proxmox it works like this).
[~] # udevadm info /dev/ttyUSBx
missing option
hmm … not work. i still have no ttyusb in my dev folder
You need to execute this on the host and replace the x with respective device number.
udevadm info /dev/ttyUSB0
udevadm info /dev/ttyUSB1
i am on the host login as admin.
say this - after plug in the Conbee III
[~] # udevadm info /dev/ttyUSB0
missing option
[~] # udevadm info /dev/ttyUSB1
missing option
i try the stick in a windows / osx machine - runs fine. But on the Qnap OS there is no USB device in the dev folder.
i have no idea as witch device this will connect.
i do the last io update, reboot, plug unplug. Shut down the conbee II Docker - handle with many option.
No way to get the Conbee as a device in my docker
this the monitor option and the result after unplug an plug the conbee III
[~] # udevadm monitor
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[268541.172662] remove   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0 (usb)
UDEV  [268541.175056] remove   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0 (usb)
KERNEL[268541.178893] unbind   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
KERNEL[268541.179392] remove   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
UDEV  [268541.182561] unbind   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
UDEV  [268541.183449] remove   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
UDEV  [268541.230680] remove   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0 (usb)
UDEV  [268541.231259] unbind   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
UDEV  [268541.430444] remove   /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
KERNEL[268546.602187] add      /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
KERNEL[268546.610440] add      /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0 (usb)
KERNEL[268546.610863] bind     /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
UDEV  [268546.612300] add      /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
UDEV  [268546.613531] add      /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0 (usb)
UDEV  [268546.615204] bind     /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
UDEV  [268546.891025] add      /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
UDEV  [268546.921851] add      /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0 (usb)
UDEV  [268546.922921] bind     /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3 (usb)
Unfortunately, I have the same problem.
Hardware:
QNAP TS-235D Firmware QTS 5.2.1.2930 Build 20241025
Conbee3 (Firmware 26510900)
lsusb[axel@QNAS ~]$ lsusb:
->Bus 001 Device 006: ID 0403:6015 Future Technology Devices International, Ltd
[axel@QNAS ~]$ ls -l /dev/ttyUSB*
→ no entry
Since I wanted to know whether the QNAP was working properly in principle, I searched for my old Busware Cul3 and plugged it into the same USB slot:
->Bus 001 Device 005: ID 03eb:204b Atmel Corp. LUFA USB to Serial Adapter Project
[axel@QNAS ~]$ ls -l /dev/tty*:
->crw------- 1 admin administrators 166, 0 2024-12-04 16:21 /dev/ttyACM0
Everything as expected!
On my Ubuntu laptop the conbee3 works fine.
I think it must be an outdated kernel module on the QNAP!
Regards
Axel
sudo modprobe ftdi_sio should help.
See Solved: /dev/ttyUSB0 missing with USB-to-serial adapter - QNAP NAS Community Forum
Now the ttyUSB0 device was created:-)
Thanx you made my day - now my docker is running and use the conbeeIII :slight_smile:
byby, Michael
