We can see deconz was in permit join
17:05:48:424 send permit join, duration: 65
17:07:50:423 send permit join, duration: 57
But no devices announce on log.
So, my conclusion right now is - totally no luck with deCONZ and Phoscon app - don‘t know why. I then installed Home Assistant and the Zigbee integration (ZHA), which also works with Conbee. Via Home Assistant I managed to pair 1 out of 12 devices. Many of my lights are as close as 5 meters from the Conbee. It seems I need to try a different Zigbee gateway hardware. Even my small Zigbee remote control with two AA batteries manages better in my environment than the Conbee.
You need to make sure to not have interference due to usb 3.0.
I tried now even the Raspberry Pi without the SSD and put a normal microSD in. So, no use of USB 3 anymore. The Conbee was connected to USB 2 port via 2m extension cable. The result is the same, I just could connect 1 Zigbee light, but the other 11 were not reachable. There are 5 lights as close as 6m, the others are a bit farer away.
Can you share logs while pairingwhen on the SD card?
Hi, it’s some time ago and I now managed so that everything works and I’d like to share, because maybe someone with similar problems might find this helpful.
Again my situation was the following:
Now, this is what helped me in the end.
Hope this might help others, if they have similar challenges, especially if devices are really outside and farer away.
