I want to clarify if this (real only smart/ZigBee containing G9 LED out there which is what I’m looking for) is compatible with deCONZ:
I could not find it on https://zigbee.blakadder.com so hopefully you can help here.
It is written about a Zigbee-compatible light that is also compatible with Philips Hue. It is therefore very likely that it will also work with deCONZ. BTW, nearly all lights are supported out-of-the-box, since lights are most of the time supported by the generic implementation.
Interesting. When it comes to ZigBee and especially deCONZ I learned to check prior buying or wasting hours trying to implement devices.
Nevertheless I thought about my use case once again (3 lights controlled by 4 switches) and decided to give a Shelly dimmer relay a try to continue using the existing switches. With smart light components they need constant power on and existing switches can not be used anymore.
Still a bit strange that this only single G9 on the market has no clear listing.
