I am having a weird problem with my setup.
setup:
- raspberry 4b 4gb
- raspbee II - 26780700
- phoscon 2.19.03 (but I had the issue also with previous versions)
- homeassistant 2022.12 (but I had the issue also with previous versions)
problem:
I am experiencing a weird problem where sometimes my homeassistant automations don’t start straightaway (i.e. light do not start), but only after a few seconds. It seems that the communication between the devices and phoscon get stucked for a few seconds (sometimes a couple of seconds, sometimes also 30 seconds), and then it get played after it get un-stuck. This has been happening since the last month or so.
Note that when there is this problem, nothing works, not just one light.
Example: I enter a room, nothing happens (even though light should turn on), I go away, from another room I see the light turning on after some time, even if I was in the room 30 seconds ago. So the message is sent eventually, but there’s lag.
what I tried:
- enable logs in phoscon, cannot see anything clearly wrong. A few times when the problem happened I ran to look at the logs and I can see that there is “stuff happening”, even though I am unclear of what the log messages mean, I can see that there’s communication with the devices.
- update phoscon to latest version (I am having this problem with at least the last 2 versions)
- update homeassistant multiple times to latest version
- change zigbee channel
- change home router to 5ghz only
- disable bluetooth and wifi on raspberry
- update python to 3.11
- move raspberry in different rooms of the house
- replace sd card
- restart phoscon. When restarted everything works again.
I am not sure what else to try to fix this!
Does anyone have any idea of what to try next?
I am going to post logs as soon as it happens again.
Thank you.
