First: Sorry for crossposting, i allready postet my problem in the Phsocon App Section wich was maybe wrong. If Maybe on Mod can delete it there. thanks.
Hi everyone,
I have an issue that should have been fixed in #5880.
There is a problem, when pairing a wall scene switch from JUNG type ZLLLS5004M.
When using the latest 2.28.1 the switch will be paired as “Remote” instead of “WS_4f_J_1”
The “Remote”-device has only one button, while the correct “WS_4f_J_1” has 8 buttons. So i can not map the different buttons to different actions, because there ist only on button showing up.
working, but very ugly workaround:
- downgrade to 2.23.01
- pair ZLLLS5004M
- and upgrade to latest version again.
Maybe one can have a look on it. Thanks in advance.
pair a ZLLLS5004M in latest deconz Version
Expected behavior
pair ZLLLS5004M like in 2.23.01 with the correct icon, the right descriptions and features
Environment
- Host system: PC
- Running method: Ubuntu, running in Docker Container
- Firmware version: (26720700)
- deCONZ version latest 2.28.1
- Device: (ConBee II)
- Is there any other USB or serial devices connected to the host system? yes, many? IMHO not relevant in this case.
deCONZ Logs
please ask for specific logs
Additional context
Switches:
6 x Insta WS_4f_J_1
4 x dresden elektronik Scene Switch
7 x lumi.remote.b686opcn01 Switch
Lights:
3 x dresden elektronik FLS-CT
1 x Philips LWB010
2 x innr RB 248 T
2 x GLEDOPTO GL-C-008P
7 x GLEDOPTO GL-C-006P
Sensors:
1 x TRADFRI motion sensor
5 x lumi.sensor_magnet.aq2
3 x lumi.weather
1 x lumi.sen_ill.agl01
