Hi there,
since some time my conbee II seemed to stop working, as I didn’t get any sensor data via IoBroker.
I checked, and couldn’t login via the website mentioned in the title - it states “login failed”, I also tried to reset the password, which doesn’t work either. deCONZ GUI works without problems as it seems.
Strangley enough, I restarted the device via “reboot device” in deCONZ GUI, and could login ONCE afterwards. No password change, the old password was just fine.
To get rid of problems, I did a firmware and deCONZ GUI update. Now I am at the same problem again. deCONZ GUI works (only descriptions of devices seem to be gone), can connect to the stick, but http://phoscon.de/pwa/ states “login failed”. I tried to physically remove the USB stick and plug it back in, as well as “sudo systemctl restart deconz” and also accessing via local IP instead of phoscon.de - Nothing worked so far.
Any ideas?
UPDATE: I tinkered around a bit more (restarting, pulling USB stick out and in) and now the icon for the conbee 2 on the website is greyed out / not clickable anymore. No clue what caused this. deCONZ GUI seems to be able to connect just fine.
Thanks
