my Fyrtur was working without an issue for years, but since recent update of deconz they stopped working via Phoscon unfortunately.
My setup:
RPi with deconz running in a docker (deconz-docker project v. 2.22.02)
ConBee2 stick
So, I can see as well as control(Windows covering) the Fyrtur in the deconz App via VNC.
The Fyrtur also appears in the Phoscon in a browser but I can’t control them there.
I assume I dont need the DDF since I can control the blinds via deconz already, correct?
Any clue or advise what I need to do to make them work?
You can see a device in deconz (so included in the zigbee network) but this one can be not in the API (so not supported) and so not usable by third app. If I m right ATM this device NEED the DDF to be correclty included in the API.
If you have the GUI, you can select the node, make edit DDF and check the DDF state (bronze/silver/gold). But on the version you have the native DDF is “gold”, so I think you are using the DDF or you have disabled them ?
correct the device is included in the zigbee network but I cant control it via Phoscon(so via the API I guess). Control vial GU works however.
When I check in the GUI I can see DDF mode is basic(there is also hybrid and strict) with Gold selected.
But I am not sure what this means, my old setup run for years without issues and I cant remember that I needed to change something in there? - but I am happy to learn.
Ok, I just found the Edit DDF option but I am not sure yet, what I can do with it?
Nothing ^^, it’s just a check to be sure the DDF is used, for exemple just go on “preview” tab and read the “status”, you need to have “gold” (mean you are using the good defaut DDF)
Ha ? I haven’t read that.
Phoscon is not able to manage covering (it can have worked previsouly but now state/on is deprecated)
You haven’t other third app ?
@Smanar
Yes, I use iobroker as third party, for me however it was always Phoscon as an indicator if everything is working as it should.
In the meantime I managed to make the Fyrtur move again via iobroker by following your instructions to replace the existing DDF with the one from Git. Thanks a lot!
Is there actually any proper explanation why the correct DDF is not added right away into deconz but why its necessary to replace it manually?
Last but not least I still can’t use the remote to control the blinds. In the past it was necessary to group the fyrtur with the remote in the legacy Phoscon app but this is not working anymore.
Was there a change here as well? Any ideas?
You don’t need.
The DDF is now official and with the “gold” state. So there is nothing to do on recent version.
You probably use “on” and “bri” previsouly ? And now you need to use only “open” and “lifft”.
This is not working ? you can see both devices but can’t link them ?
In iobroker I get following message: deconz.0 2023-07-02 16:52:12.665 warn Code 400: Bad request set light state 4: [{"error":{"address":"/lights/4/state","description":"parameter, bri, not available","type":6}},{"error":{"address":"/lights/4/state","description":"parameter, on, not available","type":6}}]
Can I change the ddf to old version?
Or can @Smanar check the correct ddf for Ikea Fyrtur blind?
@Siggi Apparently, iobroker is working with deprecated resource items (see Lights - deCONZ REST-API). It is advisable that this is changed accordingly. The issue is not with deconz in this case.
ok, I also fixed the remote.
In the old phoscon webinterface I had to add the “configuration tool” as well to the group of the ikea remote. So far I only grouped the remote with the blinds.
