I have the same issue as described by @proggprod, incl. a node once joining only halfway. Right now I can’t get any device to join my network incl. some which where previously on the network and which I had deleted but currently everything which is on my network still works.
What I’ve tried:
Exclude distance issues (Conbee 1m from switch with direct line of sight)
Rebooted deConz
Tried different devices incl. one which I had previously on the network and had meanwhile deleted
No luck.
I’ve also checked for “info” “info_l2” "error " “error_l2” and “APS” and none are in the log. I also reviewed the Zigbee configurations and there where no changes in the network key or channel in the three recorded configs.
I’m on deConz v2.21.2.
Anything I can do? I’m literally at my wits end.
Yes, I’m sure. I tried three different devices. All three types of which I had previously successfully paired. Two Tuya and one Aqara and for all of them it is the same. Long press a button until the light starts blinking.
Like I said, I tested all three types of devices previously and pairing was no problem. Now nothing wants to pair.
I would be sure it is a hardware issue of the rest of the network would operate normally.
Thanks for sharing. I was thinking that I was too stupid. After changing batteries the device couldn’t be added again. I thought it was broken and ordered new devices in China which took some time. Out of 3 devices I got 1 added accidentally somewhen and I have no idea how I did it. This was enough so far.
