I’m trying to add some Aqara Door Sensors but it is not working.
In the deconz view I can see them only in this pattern: 0xC963
I also resettet my gateway and changed the channel to 15 but nothing worked.
My Setup:
- Host system: Raspberry Pi 4
- Running method: Home Assistent deCONZ Add-on
- Firmware version: 26660700
- deCONZ version: 2.12.06
- Device: ConBee II
- Is there any other USB or serial devices connected to the host system? If so: SSD
Screenshot:
Logs when try to add two different Aqara Door sensors:
first sensor:
13:53:46:250 drop request to zombie (rx = 0)
13:53:48:747 unknown node 0x54EF44100025B794 (0x2792), lqi: 71
13:53:48:747 APS-DATA.indication from unknown node 0x54EF44100025B794
13:53:48:751 new node - ext: 0x54ef44100025b794, nwk: 0x2792
13:53:48:752 device announce 0x54EF44100025B794 (0x2792) mac capabilities 0x80
13:53:48:752 set fast probe address to 0x54EF44100025B794 (0x2792)
13:53:48:752 FP indication 0x0000 / 0x0013 (0x54EF44100025B794 / 0x2792)
13:53:48:753 … (0x54EF44100025B794 / 0x2792)
13:53:48:753 device announce 0x54EF44100025B794 (0x2792) mac capabilities 0x80
13:53:49:645 [1] get node descriptor for 0x54ef44100025b794
13:53:50:203 DB UPDATE device_descriptors SET data = x’0240805f11424200002a420000’, timestamp = 1637412830 WHERE device_id = (SELECT id FROM devices WHERE mac = ‘54:ef:44:10:00:25:b7:94’) AND endpoint = 0 AND type = 2
13:53:50:204 DB INSERT INTO device_descriptors (device_id, endpoint, type, data, timestamp) SELECT id, 0, 2, x’0240805f11424200002a420000’, 1637412830 FROM devices WHERE mac = ‘54:ef:44:10:00:25:b7:94’
13:53:50:212 FP indication 0x0000 / 0x8002 (0x54EF44100025B794 / 0x2792)
13:53:50:213 … (0x54EF44100025B794 / 0x2792)
13:53:50:213 ZDP indication search sensors 0x54EF44100025B794 (0x2792) cluster 0x8002
13:53:50:213 ZDP indication search sensors 0x54EF44100025B794 (0x2792) clear timeout on cluster 0x8002
13:53:50:219 [2] get active endpoints for 0x54ef44100025b794
13:53:52:536 FP indication 0x0104 / 0x0000 (0x54EF44100025B794 / 0x2792)
13:53:52:537 … (0x54EF44100025B794 / 0x2792)
13:53:52:538 ZCL attribute report 0x54EF44100025B794 for cluster: 0x0000, ep: 0x01, frame control: 0x18, mfcode: 0x0000
13:53:52:543 wait response fastEnddeviceProbe() 0x54EF44100025B794, elapsed 2323 ms
13:53:53:536 FP indication 0x0000 / 0x8005 (0x54EF44100025B794 / 0x2792)
13:53:53:537 … (0x54EF44100025B794 / 0x2792)
13:53:53:538 ZDP indication search sensors 0x54EF44100025B794 (0x2792) cluster 0x8005
13:53:53:538 ZDP indication search sensors 0x54EF44100025B794 (0x2792) clear timeout on cluster 0x8005
13:53:53:544 [3] get simple descriptor 0x01 for 0x54ef44100025b794
13:53:54:547 FP indication 0x0000 / 0x8005 (0x54EF44100025B794 / 0x2792)
13:53:54:548 … (0x54EF44100025B794 / 0x2792)
13:53:54:548 ZDP indication search sensors 0x54EF44100025B794 (0x2792) cluster 0x8005
13:53:54:554 wait response fastEnddeviceProbe() 0x54EF44100025B794, elapsed 1009 ms
13:53:58:553 DB UPDATE device_descriptors SET data = x’010401020402050000010003000005c0fc0203001900’, timestamp = 1637412838 WHERE device_id = (SELECT id FROM devices WHERE mac = ‘54:ef:44:10:00:25:b7:94’) AND endpoint = 1 AND type = 4
13:53:58:554 DB INSERT INTO device_descriptors (device_id, endpoint, type, data, timestamp) SELECT id, 1, 4, x’010401020402050000010003000005c0fc0203001900’, 1637412838 FROM devices WHERE mac = ‘54:ef:44:10:00:25:b7:94’
13:53:58:568 FP indication 0x0000 / 0x8004 (0x54EF44100025B794 / 0x2792)
13:53:58:568 … (0x54EF44100025B794 / 0x2792)
13:53:58:568 ZDP indication search sensors 0x54EF44100025B794 (0x2792) cluster 0x8004
13:53:58:569 ZDP indication search sensors 0x54EF44100025B794 (0x2792) clear timeout on cluster 0x8004
13:53:58:575 [3.1] get IAS Zone type for 0x54ef44100025b794
13:53:59:575 FP indication 0x0104 / 0x0500 (0x54EF44100025B794 / 0x2792)
13:53:59:575 … (0x54EF44100025B794 / 0x2792)
13:53:59:576 Clear fast probe timeout for cluster 0x0500, 0x54EF44100025B794
13:54:08:758 saved node state in 0 ms
13:54:08:758 sync() in 0 ms
second sensor:
13:53:46:250 drop request to zombie (rx = 0) 13:53:48:747 unknown node 0x54EF44100025B794 (0x2792), lqi: 71 13:53:48:747 APS-DATA.indication from unknown node 0x54EF44100025B794 13:53:48:751 new node - ext: 0x54ef44100025b794, nwk: 0x2792 13:53:48:752 device announce 0x54EF44100025B794 (0x2792) mac capabilities 0x80 13:53:48:752 set fast probe address to 0x54EF44100025B794 (0x2792) 13:53:48:752 FP indication 0x0000 / 0x0013 (0x54EF44100025B794 / 0x2792) 13:53:48:753 ... (0x54EF44100025B794 / 0x2792) 13:53:48:753 device announce 0x54EF44100025B794 (0x2792) mac capabilities 0x80 13:53:49:645 [1] get node descriptor for 0x54ef44100025b794 13:53:50:203 DB UPDATE device_descriptors SET data = x'0240805f11424200002a420000', timestamp = 1637412830 WHERE device_id = (SELECT id FROM devices WHERE mac = '54:ef:44:10:00:25:b7:94') AND endpoint = 0 AND type = 2 13:53:50:204 DB INSERT INTO device_descriptors (device_id, endpoint, type, data, timestamp) SELECT id, 0, 2, x'0240805f11424200002a420000', 1637412830 FROM devices WHERE mac = '54:ef:44:10:00:25:b7:94' 13:53:50:212 FP indication 0x0000 / 0x8002 (0x54EF44100025B794 / 0x2792) 13:53:50:213 ... (0x54EF44100025B794 / 0x2792) 13:53:50:213 ZDP indication search sensors 0x54EF44100025B794 (0x2792) cluster 0x8002 13:53:50:213 ZDP indication search sensors 0x54EF44100025B794 (0x2792) clear timeout on cluster 0x8002 13:53:50:219 [2] get active endpoints for 0x54ef44100025b794 13:53:52:536 FP indication 0x0104 / 0x0000 (0x54EF44100025B794 / 0x2792) 13:53:52:537 ... (0x54EF44100025B794 / 0x2792) 13:53:52:538 ZCL attribute report 0x54EF44100025B794 for cluster: 0x0000, ep: 0x01, frame control: 0x18, mfcode: 0x0000 13:53:52:543 wait response fastEnddeviceProbe() 0x54EF44100025B794, elapsed 2323 ms 13:53:53:536 FP indication 0x0000 / 0x8005 (0x54EF44100025B794 / 0x2792) 13:53:53:537 ... (0x54EF44100025B794 / 0x2792) 13:53:53:538 ZDP indication search sensors 0x54EF44100025B794 (0x2792) cluster 0x8005 13:53:53:538 ZDP indication search sensors 0x54EF44100025B794 (0x2792) clear timeout on cluster 0x8005 13:53:53:544 [3] get simple descriptor 0x01 for 0x54ef44100025b794 13:53:54:547 FP indication 0x0000 / 0x8005 (0x54EF44100025B794 / 0x2792) 13:53:54:548 ... (0x54EF44100025B794 / 0x2792) 13:53:54:548 ZDP indication search sensors 0x54EF44100025B794 (0x2792) cluster 0x8005 13:53:54:554 wait response fastEnddeviceProbe() 0x54EF44100025B794, elapsed 1009 ms 13:53:58:553 DB UPDATE device_descriptors SET data = x'010401020402050000010003000005c0fc0203001900', timestamp = 1637412838 WHERE device_id = (SELECT id FROM devices WHERE mac = '54:ef:44:10:00:25:b7:94') AND endpoint = 1 AND type = 4 13:53:58:554 DB INSERT INTO device_descriptors (device_id, endpoint, type, data, timestamp) SELECT id, 1, 4, x'010401020402050000010003000005c0fc0203001900', 1637412838 FROM devices WHERE mac = '54:ef:44:10:00:25:b7:94' 13:53:58:568 FP indication 0x0000 / 0x8004 (0x54EF44100025B794 / 0x2792) 13:53:58:568 ... (0x54EF44100025B794 / 0x2792) 13:53:58:568 ZDP indication search sensors 0x54EF44100025B794 (0x2792) cluster 0x8004 13:53:58:569 ZDP indication search sensors 0x54EF44100025B794 (0x2792) clear timeout on cluster 0x8004 13:53:58:575 [3.1] get IAS Zone type for 0x54ef44100025b794 13:53:59:575 FP indication 0x0104 / 0x0500 (0x54EF44100025B794 / 0x2792) 13:53:59:575 ... (0x54EF44100025B794 / 0x2792) 13:53:59:576 Clear fast probe timeout for cluster 0x0500, 0x54EF44100025B794 13:54:08:758 saved node state in 0 ms 13:54:08:758 sync() in 0 ms
happy you found it!
