Cannot stop deconz via systemctl
Hey,
I am using deconz in a Debian VM (Debian 11).
Now recently I updated deconz and everything else to latest version (2.31.2).
It currently works well after a VM restart.
But if I want to stop it via
sudo systemctl stop deconz
the command takes a very long time. During that time, systemctl status deconz shows:
Active: deactivating (stop-sigterm) since … (30–50s)
CPU usage stays very low (around 2–5%), so the process does not seem busy.
After ~30 seconds, the service fails with a timeout:
Active: failed (Result: timeout)
The journalctl then shows:
systemd[1]: Stopping deCONZ: ZigBee gateway -- REST API...
systemd[1]: deconz.service: State 'stop-sigterm' timed out. Killing.
systemd[1]: deconz.service: Killing process XXXX (deCONZ) with signal SIGKILL.
systemd[1]: deconz.service: Main process exited, code=killed, status=9/KILL
systemd[1]: deconz.service: Failed with result 'timeout'.
If I then try to start it again, it hangs. :confused:
My service looks like this:
### /etc/systemd/system/deconz.service
[Unit]
Description=deCONZ: ZigBee gateway -- REST API
Wants=deconz-init.service deconz-update.service
StartLimitIntervalSec=0
[Service]
User=1000
ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80 --dev=/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_Co>
Restart=on-failure
RestartSec=30
AmbientCapabilities=CAP_NET_BIND_SERVICE CAP_KILL CAP_SYS_BOOT CAP_SYS_TIME
[Install]
WantedBy=multi-user.target
Any suggestions what could be the reason?
EDIT:
Further investigations:
Is it correct that this is always running in the background?
root 398 0.0 0.3 7028 3108 ? Ss 11:50 0:04 /bin/bash /usr/bin/deCONZ-update2.sh
On my side, on classic OS (Raspbian)
If I close it, have the same issue, and not possible to restart it because of deconz-autostart.sh
#check if deCONZ already running
pidof deCONZ
if [ $? -eq "0" ]; then
    echo "deCONZ already running"
    exit 1
fi
To restart deconz I need to make
pi@raspberrypi:~ $ pidof deCONZ
16830
pi@raspberrypi:~ $ sudo pkill 16830
Interesting. :slight_smile: So I am not alone.
Did you consider, adding some lines to the service telling it to use your kill method for shutdown? That was AIs suggestion for me, but it certainly is a workaround for a bug that only the devs can fix, right?
Yes, the problem is direclty in the deconz application for me, the application hang at close, but it something recent, and probably already corrected.
The version 2.31.2 have (critic for me) some issues, already patched, but for the moment I m waiting the 2.31.3 to make test.
I don’t restart deconz often, for the moment I type the shell commands myself, I don’t use workaround yet.
Oh ok, so you can confirm that this is indeed a bug in deconz? Was it noted in GitHub or how do you know? Because then I’d also leave it as is. I also restart it very rarely - and if I need to, I can still quickly restart my whole VM. I just wanted to know if I have a messed up config. :smiley:
But if you have a GitHub issue or something, I could follow that to see, when an update for me is due to fix this. :slight_smile:
ha no ^^, I have just see the issue too, I have say it on dev channel on discord, I had no reaction.
For me better to wait for next version first to see if the issue is still here, there is already some patchs planned.
Strange we are only 2 with this issue (or few users try to restart deconz), it’s nice you have started something, to have more return, and dev reads the forum too.
This fix:
was integrated in 2.32.3 Beta on 15th of January.
Maybe that fixes it, but the versions are all still beta.
The v2.32.4-beta is out, I will make a try today.
I m on version v2.32.4-beta ATM.
I can’t say if it’s better, I have tried to close it and reopen it fastly, I need 4s max delay (On raspberry 3), and it works.
But before installing the new version, have made a try on the previous version, and it have worked too, so the issue can be random.
Nice, but that sounds promising. Do you actively choose the beta upgrade path? Because if so, I will probably just wait until 2.32.2 is released in the stable branch.
On my side I just download the package and install it.
But yes, with all issues we had with previous version, lot of chance to have a stable version soon, for the moment no bad return with v2.32.4-beta.
Ok so the issue is still here
Not possible to kill deconz, and my previous command is not working, the only way I have found is
pgrep -io deconz | xargs kill -KILL
So this issue still persists? oO That is annoying. I never got around updating it since the presumed fix version was still beta.
I just tried, this also didn’t work for me. I need to wait about 2 minutes so that whatever-it-is times out, then I can restart deconz without rebooting the VM. :confused:
I also noticed this on 2.33.1 today …
Stopping the service took much longer than usual.
RPi 4 w/SSD.
Debian 1:6.12.93-1+rpt1 (2026-06-12) aarch64 GNU/Linux
Claude Code told me, while analyzing my DeConz system, that since deCONZ ignores SIGTERM, systemd waits out its full 90-second default stop timeout on every systemctl restart deconz, shutdown, or reboot before finally killing the process with SIGKILL (you’ll see deconz.service: State ‘stop-sigterm’ timed out. Killing. in the journal). As a workaround, you can shorten the pointless wait by creating a drop-in file at /etc/systemd/system/deconz.service.d/stop-timeout.conf containing [Service] and TimeoutStopSec=10, then running sudo systemctl daemon-reload. This is safe because deCONZ already gets SIGKILLed on every stop anyway (its state lives in a crash-safe SQLite database that’s written continuously during operation, not on exit), and using a drop-in instead of editing the unit file means the fix survives deconz package updates and can be reverted by simply deleting the file.
But oh well… strange, that we need this?
