Hi there,
I am not able to pair my conbee II running Phoscon with my brand new Aqara Sensor… I have already several sensors (Aquara Temperature f.e) but this one does not apear…
I updated deconz within my raspbean and also the conbee2 to the newest firmware…
but it is still not beeing found …
thanks for your answer Gautama,
the deCONZ Version is 2.19.03 / 19.9.2022
the Firmware 26720700
There is a sticker at the package with a serial nr and the SKU: AS006UEW01 Prod Date 10/22
Does this help ?
Mimiix: What do you mean with 220v ? I have several other sensors using in my phoscon enviroment some temperature/humidity and water sensor from Aqara, too…
I am not sure about the deConz app, I cant find the edit/Join dialog as described in the documentation to let the new sensor “in” the network … If I just start the app and try to pair my sensor , I cant see anything… But I can see the other 7 already mounted sensors in the network …
