Cannot install firmware deCONZ_RaspBeeII_0x26720700.bin.GCF
I just tried to install latest firware because I was not able to connect (first time ever) to gateway RASPBEE2. But I got following error.
Please note that I requested to download deCONZ_RaspBeeII_0x26720700.bin.GCF but I got back deCONZ_RaspBeeII_0x26720700.bin.GCF.2
pi@raspberrypi:~ $ sudo GCFFlasher_internal -t 60 -f deCONZ_RaspBeeII_0x26720700.bin.GCF.2
deCONZ firmware version 26720700
Bootloader version 0x00030003, app crc: 0x01BB96DC
action: reset device RaspBee
wiringPi 2.52 initialized
flashing 164227 bytes: |================|retry, failed
deCONZ never worked before: I’m not able to see the gateway via web app. Setting → Gateway → Advanced → Auth App…
Moreover I tried to discover my first sensor ( Aquara WSDCGQ11LM) but nothing is discovered.
What is the current setup? Is there a ssd involved? Can you provide some logs?
Hello Mimiix, I solved the problem (I hope). I did 2 actions:
  1. I flashed for the 3rd time the Raspbee2 ( I got again the error “retry failed”) , then I powered off and on the Raspberry PI4.
  2. In the meantime I decided to move the Raspberry PI4 ( with the Raspbee2 inside and the external boot USB disk attached to USB2 ) in another physical locations. In fact it was toghether with other devices below my SmartTV with other devices with their power supplies: I suspected too many magnectic waves masking the Raspbee2 antenna.
Then I started Phoscon App and I was able to see the Gateway and I was able to pair the sensors I wanted to monitor.
I din’t try to re-flash the Raspbee2… at the moment I would not.
Let me stabilize the configuraztion, then I will think to go deeper with the firmware error. (However it seems it is not a real error, even if the process doesn’t seem to be stable and perfectly tested).
I wish thank you for your kind attention and support.
Giuseppe.
Hello! I have the same problem, i.e. the flash ends with an error message.
Info about my system/kernel in use (a RaspBerry Pi 2 with RaspBee II module):
pi@phoscon:~ $ uname -a
Linux phoscon 5.10.17-v7+ #1421 SMP Thu May 27 13:59:01 BST 2021 armv7l GNU/Linux
Thus, I want to see the device path:
pi@phoscon:~ $ GCFFlasher_internal -l
Path             | Vendor | Product | Serial     | Type
/dev/ttyAMA0     | 0x0000 | 0x0000  |            | RaspBee
(BTW, why are vendor and product IDs null?)
And this, to my understanding, is the correct flash command (with correct device path), but it fails:
pi@phoscon:~ $ sudo GCFFlasher_internal -d /dev/ttyAMA0 -t 120 -R 3 -f deCONZ_RaspBeeII_0x26720700.bin.GCF
Reboot device /dev/ttyAMA0 (RaspBee)
failed reset 19941
flashing 164227 bytes: |================|Reboot device /dev/ttyAMA0 (RaspBee)
failed reset 19845
What am I missing? Thanks for your help!
PS @Mimiix
I posted the (almost) same there:
I completed flashed my Raspberry Pi 2 with the latest stable build as a workaround.
