Hi Leute, ich bin neu hier. Ich habe Phocon jetzt auf meinem Raspberry Pi installiert. Ich finde allerdings keine Schalter. Muss ich noch was weiteres auf meiner Homebridge installieren? Danke schonmal!
Hi guys, I’m new here. I installed Phoco on my Raspberry Pi now. I don’t find switches, though. Do I have to install anything else on my homebridge? Thank you!
In deconz you have only “light” (powered device) and “sensors” (battery device), in reality it’s more complex, the on/off feature on a plug is a “light” and the measurement are “sensor”.
“switch” is a sub division of “sensors”.
But as it’s your first devices, you can have a setting problem.
The firmware is displayed in phoscon/gateway ?
Have you the deconz application ? the GUI, to check logs ?
Wich one reset procedure are you using for this device ?
And as you have an empty network, you can install deconz on a windows machine, like that easier to get log and you can try the conbee on another hardware (usefull to check hardware issue, power, extension cable and ect …)
The GUI is the graphical application, if you have an headless OS can be complicated, it’s for that it’s easier to make the test on a windows machine.
