Cannot connect to Conbee II - Failed open com status (-3)
Hi all,
I am running a Conbee II on my Raspberry PI. It has been up and running for months without any troubles - until a few days ago. Now I cannot connect to the Conbee at all, and deCONZ only detects Raspbee on startup. I cannot select the Conbee II in deCONZ at all.
In addition I get the following errors on loop:
12:16:29:600 COM: /dev/ttyACM0 : (0x1106/0x3483)
12:16:29:600 COM: /dev/ttyAMA0 : (0x0000/0x0000)
12:16:29:601 dev /dev/ttyAMA0
12:16:29:601 failed open com status: (-3), path: /dev/ttyAMA0
The only thing we have done is cut the power to the Raspberry PI a few times, due to other electrical work. I have also tested the Conbee II on another machine, which connects to it perfectly. I have also tried reinstalling everything regarding deCONZ, to no avail.
In addition, when I try to open network settings in the startup screen of deCONZ, nothing happens. I do not know if this is related or not.
I am running firmware 26720700 and the Phoscon app starts without trouble.
Any idea as to how to fix this?
Looks like this might be your issue
Hi Mimiix,
Thanks for that. The command “deCONZ --dev=/dev/ttyACM0” worked for me and got it working!
