I installed deCONZ docker image on my QNAP via Container Station.
Unfortunately I cannot see the Conbee 3 in the list of devices, it connects but does not appear in /dev.
On a Windows laptop it works, on a raspberry it works as well.
I tried to connect the Conbee 2 on the QNAP and it shows as expected on the same usb port where the Conbee 3 was attached.
Below log output first the Conbee 2 and than the Conbee 3:
dmesg
[ 491.747944] usb 1-3: new full-speed USB device number 3 using xhci_hcd
[ 491.884464] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
[ 491.899679] [usb.001.003] /sys/devices/pci0000:00/0000:00:14.0/usb1/1-3 added.
[ 3714.123668] usb 1-3: new full-speed USB device number 7 using xhci_hcd
[ 3714.282125] [usb.001.007] /sys/devices/pci0000:00/0000:00:14.0/usb1/1-3 added.
for Conbee III 2.28.1 (26530900)
$ lsusb
Bus 001 Device 007: ID 0403:6015 Future Technology Devices International, Ltd
$ cat /sys/devices/pci0000\:00/0000\:00\:14.0/usb1/1-3/manufacturer
dresden elektronik
$ cat /sys/devices/pci0000\:00/0000\:00\:14.0/usb1/1-3/product
ConBee III
[SOLVED]
Affter few trials loading the below module allows the device to be loaded. still need to test if it actually works.
# insmod /lib/modules/others/ftdi_sio.ko
[41503.420666] usb 1-3: new full-speed USB device number 32 using xhci_hcd
[41503.565190] ftdi_sio 1-3:1.0: FTDI USB Serial Device converter detected
[41503.572790] usb 1-3: Detected FT-X
[41503.577102] usb 1-3: FTDI USB Serial Device converter now attached to ttyUSB0
[41503.592684] [usb.001.032] /sys/devices/pci0000:00/0000:00:14.0/usb1/1-3 added.
I used the below script to automatically load at startup the module on the QNAP based on this guide:
cat /tmp/config/autorun.sh
#!/bin/sh
/sbin/insmod /lib/modules/others/ftdi_sio.ko
if lsmod | grep ftdi_sio > /dev/null; then
echo `date` "[ OK ] autorun.sh: ftdi_sio.ko module loaded" >> /var/log/autorun_script.log
else
echo `date` "[FAIL] autorun.sh: failed to load ftdi_sio.ko module" >> /var/log/autorun_script.log
fi
