Bosch Room Thermostat II 230V does not connect with Conbee III
can anybody confirm successful operation of Bosch Room Thermostat II 230V with Conbee III?
I’m running deCONZ-docker on RPi5, tried lastest and stable. Conbee III is flashed with lastest firmware.
Installcode was put via Rest-API.
The thermostat does not show up at all in the deCONZ-gui. No errors visible in the log during parking process.
No Bosch-related posts here helped out so far.
Can anybody give advise on how to proceed?
Thanks in advance!
Several people have the same problem, myself included. Since I still have a Conbee II, I’m using that to pair them. Once paired, they also work with a Conbee III.
See the GitHub page for details. BOSCH Thermostat II (RBSH-TRV0-ZB-EU) cannot be connected to the Conbee III (deconz) · Issue #8027 · dresden-elektronik/deconz-rest-plugin · GitHub
Thank you for the information, @Dermayer .
Pairing with Conbee II works also for me. Important to note:
  • Entering the installcode seems to be case sensitive ( Code and MAC address)
  • MAC address must be entered without colon
  • the thermostat needs strong connection to the stick
Does anybody know, if the issue with Conbee III is related to the hardware, software or the firmware?
Is there a timeline for a fix?
I have the same problem. No connection wether ZHA or Zigbee2MQTT.
Zigbee2MQTT: install_code/add command writeparameter failed with status Usupported wspo8-4
