Bosch Radiator Thermostat II
Still not working in 2.25.1
It works, but requires navigating through numerous unnecessary steps.
  1. Obtain an API key.
  2. Locate the barcode inside the battery cover of your TRV. Next to the barcode, find two values: Zigbee EUI-64 (referred to as <device_mac_address>) and Install Code. The Install Code appears in 4-character groups separated by dashes. You’ll need this code without the dashes for the installcode JSON value.
  3. Follow the Pair with install code instructions. Ignore any confusing wording in the Parameters section. A successful operation will return a 200 OK response. Ensure accuracy when entering <device_mac_address>; a typo can still yield a 200 OK but won’t pair correctly.
  4. Proceed to pair your Bosch TRV as you would with any other device.
Yes that would be the “user-friendly” procedure. How does it help with @tstone’s hash failure?
cd /usr/lib/aarch64-linux-gnu && ln -s libcrypto.so.3 libcrypto.so did the trick on debian/arm64 (RPI) for me.
or just do apt install libssl-dev
You guys might want to highlight this to the community taking care of the docker image/container, as the issue is apparently a missing library and not an error in deconz. Thanks!
@senilio @phdelodder should help out here @Swoop
@Swoop I have had an issue on deconz debian install (without docker involved) as the deconz deb did not depend on libssl-dev.
@xz13 I’m going to approve your PR today!
@Swoop @Mimiix thanks for the poke
Hi all,
I have the same issue wiith my Bosch Smart Thermostat II, the error message is exactly like the one from h1k3r, see screenshot:
This sent me through an upgrade spiral and now I am on the official Raspberry Pi SD card image from dresden electronic (bookworm desktop):
SCR-20241014-nxvi
The strange thing is that I am perfectly able to pair the Bosch Light/Shutter control unit II using the installation code method.
If it helps to share the MAC and install code I am willing to do so via PM.
Regards,
Torsten
AFAIK, the reason it failed is because the OpenSSL lib was missing/ not installed.
That’s why your new version works :slight_smile:
I do not think this is the issue at hand, maybe I have not clearly described it in my comment above:
With the latest version of deconz (2.28.1) the pairing with the light/roller shutter worked, while it failed for the thermostat.
So this should not be a dependency issue as both processes were done on exactly the same setup.
Ok, I found the issue: I took the install code from a picture where the text was OCRd. This created a capital letter ‘O’ instead of the number ‘0’ in one place.I am now able to pair the thermostat.
Thanks to everyone who pondered the issue.
I tried the following in the windows command line on a PC in my local network (<…> are redactions):
curl -X PUT -H "Authorization: Bearer <API key>" -H "Content-Type: application/json" -d "{\"installcode\": \"<Install Code>\"}" http://<HA-IP>:8123/api/devices/<ZigBee EUI-64>/installcode
However the answer is: 404: NotFound.
Im pretty sure connections are not the issue as the following GET-command returns a sensible answer:
curl -X GET -H "Authorization: Bearer <API key>" -H "Content-Type: application/json" http://<HA IP>:8123/api/states
Any ideas on how to troubleshoot this?
@torti: what kind of interface is used in your screenshot?
Im using a RaspBee II on a RPi 4.
Thanks
Hi Sequynth,
welcome to the community.
You do not need to use the Authorisation-Header for the call. The API token is part of the URL:
<yourhost>:80/api/<api token>/devices/<device mac address>/installcode
Details can be found here: Devices - deCONZ REST-API
Looking at your HTTP call it seems a bit like you are trying to address a Home Assistant instance. Make sure you use the name/IP of the phoscon endpoint on your rpi.
The interface I am using is postman, basically a GUI for REST APIs with a lot of bells and whistles. It can be a bit overwhelming at first, once you get the hang of it it is a nice tool though.
Regards
