Blitzwolf BW-SHP15 shows kWh but not W
humm… just tried the above but GCFFlasher_internal shows no device
root@core-deconz:/# GCFFlasher_internal -l
no devices found
Path              | Serial      | Type
Not sure why, I’d expected to see my raspbee2 listed there, so what I’ve said might not work.
Maybe because raspbee it’s in use by the addon. You’d need to also stop deconz first…
I’ve also seen that there’s something for the firmware in the deconz addon code: https://github.com/home-assistant/addons/blob/master/deconz/rootfs/etc/cont-init.d/firmware.sh
but not sure how to use/if it’s useful.
i just stick to the old one i guess or are there any known security concerns? That might be the point where i lack confidence in updating. Read from some guys who bricked there raspbees during that process.
did it :stuck_out_tongue:
worked exactly like described here if someone needs the info:
How to update conbee II on hassio with deconz/phoscon integration? - Configuration / Zigbee - Home Assistant Community (home-assistant.io)
mine showed no device too but after using /dev/ttyAMA0 as device path it worked like it should
