So this still renders data unusable, which became a more important issue due to some statistics done with the consumption values:
- Any new progress on this?
- Or any other ideas?
- How (content of DDF) would I ignore/suppress the values of
0(zero) for current consumption so they are not reported at all? I’d at least give that a try just to see what it would look like in Home Assistant in the end and if it has any (not acceptable) side effects. I’d need a custom DDF based on the default one with a) just for the_TZ3000_amdymr7land with the"name": "state/consumption",section modified in a way it ignores value of0(zero).
Similar to what we did with the battery value for another device here:
