Is there a way to show all bindings of a device? Sometimes I have to reset a device and deCONZ does not automatically re-apply the binding, so it would be good to know what I did before.
There is this button “Read binding table” but nothing happens when I press it
Is here just the UI missing to show the bindings? If yes, can you just print them to the console / logs?
Bonus: bindings via REST API would be really nice (zigbee2mqtt has this)
Hmm, ok, but the bindings we do manually are also done by deConz, right?
In my screenshots you can see bindings “On/Off” & “Level Control”, basically what I initiated yesterday between 2 devices after your support to understand that binding topic.
Debug Window stays empty. Selected ZGP and then Read Node Info on my STYRBAR. When I select ZDP I see messages like
08:24:35:832 ZDP 0x001788010BD7CFE9 cluster: 0x8033 status = 0x00 -> SUCCESS
08:24:35:833 found binding 0x0001, 0x01 -> 0x00212EFFFF04FE3D : 0x01
08:24:35:834 found binding 0xFC00, 0x01 -> 0x00212EFFFF04FE3D : 0x01
08:24:35:835 found binding 0x0008, 0x01 -> 0x0022
08:24:35:836 found binding 0x0006, 0x01 -> 0x0022
but 0x001788010BD7CFE9 is not the STYRBAR (its the Hue Dimmer switch I did not touch) and 0x00212EFFFF04FE3D is not the light its bound to (its the Conbee III).
