Best practice Update raspbian buster to trixie with Conbee II
Hey there,
is there a best practice to update from buster to trixie on raspberry with a conbee ii? I tried an export via phoscon on buster and import on trixie. The gateway shows the conbee firmware version but „unkown“ in the device / vendor information. Also all zigbee devices are visible, but not controllable.
Thanks Daniel
Hello, your procedure is the good one. You are using the backup/retore feature from Phoscon ?
Are you sure deconz is correctly installed on the Trixie machine ?
Can you take a look on the deconz logs ? Deconz/help/Debug View with flag “info” 2 and “error” 2 ?
outdated, see next post
Hi
I just tested if it was the backup and purged deconz and reinstalled.
In an empty installation I see a „not connected“ in the firmware line in Phoscon. lsusb is showing the conbee ii correctly.
I started that empty deconz with dbg-info=2 and dbg-error=2, logfile is attachted
pi@raspberrypi4:~/.local/share $ sudo /usr/bin/deCONZ -platform minimal --http-port=80 --dbg-info=2 --dbg-error=2
22:15:19:743 /root/.local/share/dresden-elektronik/deCONZ/config.ini exists and is writeable
22:15:19:743 /root/.local/share/dresden-elektronik/deCONZ/zll.db exists and is writeable
22:15:19:848 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:15:19:863 ZCLDB init file /root/.local/share/dresden-elektronik/deCONZ/zcldb.txt
22:15:19:898 void deCONZ::ZclDataBase::load(const QString&),3518: assertion 'val <= nt->max' failed
22:15:19:899 void deCONZ::ZclDataBase::load(const QString&),3518: assertion 'val <= nt->max' failed
22:15:19:920 void deCONZ::ZclDataBase::load(const QString&),3517: assertion 'val >= nt->min' failed
22:15:19:956 HTTP Server listen on address 0.0.0.0, port: 80, root: /usr/share/deCONZ/webapp/
22:15:19:967 HTTPS server listening on port: 443
22:15:20:444 DDF enabled for Gold status
22:15:20:445 parent process sudo
22:15:20:445 gw run mode: normal
22:15:20:445 GW sd-card image version file does not exist: /root/.local/share/dresden-elektronik/deCONZ/gw-version
22:15:20:445 sd-card cid: 035344534433324785ffffffff014c00
22:15:20:446 DB sqlite version 3.42.0
22:15:20:447 DB PRAGMA page_count: 48
22:15:20:447 DB PRAGMA page_size: 4096
22:15:20:447 DB PRAGMA freelist_count: 0
22:15:20:447 DB file size 196608 bytes, free pages 0
22:15:20:447 DB PRAGMA user_version: 10
22:15:20:447 DB cleanup
22:15:20:447 DB create temporary views
22:15:20:447 DB view [0] created
22:15:20:448 DB view [1] created
22:15:20:448 DB view [2] created
22:15:20:448 DB view [3] created
22:15:20:477 DeviceDescription::Item DDF_ParseItem(DDF_ParseContext*, const QJsonObject&),3242: assertion 'rid.type == DataTypeString || rid.type == DataType            Time || rid.type == DataTypeTimePattern' failed
22:15:20:774 sql exec SELECT apikey,devicetype,createdate,lastusedate,useragent FROM auth
22:15:20:774 sql exec SELECT key FROM config2
22:15:20:774 sql exec SELECT key,value FROM config2
22:15:20:774 Load config UTC: 2026-07-04T20:12:42 from db.
22:15:20:774 Load config announceinterval: 45 from db.
22:15:20:774 Load config announceurl: https://phoscon.de/discover from db.
22:15:20:774 Load config apiversion: 2.33.1 from db.
22:15:20:774 Load config bridgeid: 00212EFFFF06C9BE from db.
22:15:20:774 Load config datastoreversion: 93 from db.
22:15:20:774 Load config dhcp: true from db.
22:15:20:774 Load config disablePermitJoinAutoOff: false from db.
22:15:20:774 Load config discovery: false from db.
22:15:20:774 Load config factorynew: false from db.
22:15:20:774 Load config fwneedupdate: false from db.
22:15:20:774 Load config fwupdatestate: idle from db.
22:15:20:774 Load config fwversion: 0x00000000 from db.
22:15:20:774 Load config gateway: 127.0.0.1 from db.
22:15:20:774 Load config group0: 65520 from db.
22:15:20:775 Load config groupdelay: 50 from db.
22:15:20:775 Load config gwpassword: $1$8282jdkm$w.o6XjJEGLzAYkVqLPAYx1 from db.
22:15:20:775 Load config gwusername: delight from db.
22:15:20:775 Load config homebridge: not-managed from db.
22:15:20:775 Load config homebridge-pin:  from db.
22:15:20:775 Load config homebridgepin:  from db.
22:15:20:775 Load config homebridgeupdate: false from db.
22:15:20:775 Load config homebridgeupdateversion:  from db.
22:15:20:775 Load config homebridgeversion:  from db.
22:15:20:775 Load config ipaddress: 192.168.2.69 from db.
22:15:20:775 Load config lightlastseeninterval: 60 from db.
22:15:20:775 Load config linkbutton: false from db.
22:15:20:775 Load config localtime: 2026-07-04T22:12:42 from db.
22:15:20:775 Load config mac: 38:60:77:7c:53:18 from db.
22:15:20:775 Load config modelid: deCONZ from db.
22:15:20:775 Load config name: Phoscon-GW from db.
22:15:20:775 Load config netmask: 255.0.0.0 from db.
22:15:20:775 Load config networkopenduration: 60 from db.
22:15:20:775 Load config otauactive: false from db.
22:15:20:775 Load config otaustate: off from db.
22:15:20:775 Load config panid: 0 from db.
22:15:20:775 Load config permitjoin: 0 from db.
22:15:20:775 Load config permitjoinfull: 0 from db.
22:15:20:775 Load config port: 80 from db.
22:15:20:775 Load config portalservices: false from db.
22:15:20:775 Load config proxyaddress: none from db.
22:15:20:775 Load config proxyport: 0 from db.
22:15:20:775 Load config rfconnect: 1 from db.
22:15:20:775 Load config rfconnected: false from db.
22:15:20:775 Load config rgbwdisplay: 1 from db.
22:15:20:775 Load config runmode: normal from db.
22:15:20:775 Load config starterkitid:  from db.
22:15:20:775 Load config swcommit: cd7621f0a3aeaf977dc93231d6bca8ef24544291 from db.
22:15:20:775 Load config swupdatestate: noupdates from db.
22:15:20:775 Load config swversion: 2.33.1 from db.
22:15:20:775 Load config system: linux-gw from db.
22:15:20:775 Load config timeformat: 12h from db.
22:15:20:775 Load config timezone: Europe/Berlin from db.
22:15:20:775 Load config updatechannel: stable from db.
22:15:20:775 Load config uuid: 76d39110-6c7a-4639-bdf5-ba8d84a7e771 from db.
22:15:20:775 Load config websocketnotifyall: true from db.
22:15:20:775 Load config websocketport: 0 from db.
22:15:20:775 Load config wifi: not-configured from db.
22:15:20:775 Load config wifibackupname:  from db.
22:15:20:775 Load config wifibackuppw:  from db.
22:15:20:775 Load config wifibackuppwenc:  from db.
22:15:20:775 Load config wifichannel: 1 from db.
22:15:20:775 Load config wificlientname:  from db.
22:15:20:775 Load config wificlientpw:  from db.
22:15:20:775 Load config wifiip: 192.168.8.1 from db.
22:15:20:775 Load config wifilastupdated: 0 from db.
22:15:20:775 Load config wifimgmt: 0 from db.
22:15:20:775 Load config wifiname:  from db.
22:15:20:775 Load config wifipageactive: false from db.
22:15:20:775 Load config wifipw:  from db.
22:15:20:775 Load config wifipwenc:  from db.
22:15:20:775 Load config wifitype: accesspoint from db.
22:15:20:775 Load config workingname:  from db.
22:15:20:775 Load config workingpw:  from db.
22:15:20:775 Load config workingpwenc:  from db.
22:15:20:775 Load config workingtype:  from db.
22:15:20:775 Load config zclvaluemaxage: 0 from db.
22:15:20:775 Load config zigbeechannel: 15 from db.
22:15:20:775 sql exec SELECT key,value FROM userparameter
22:15:20:775 sql exec SELECT * FROM groups
22:15:20:775 Sqlite group: gid = 0xFFF0
22:15:20:775 Sqlite group: name = All
22:15:20:775 Sqlite group: state = normal
22:15:20:775 Sqlite group: hidden = false
22:15:20:775 Sqlite group: type = LightGroup
22:15:20:775 Sqlite group: class = Other
22:15:20:775 DB found group All 0xFFF0
22:15:20:776 sql exec SELECT * FROM resourcelinks
22:15:20:776 sql exec SELECT * FROM scenes
22:15:20:776 sql exec SELECT * FROM rules
22:15:20:776 sql exec SELECT * FROM schedules
22:15:20:776 sql exec SELECT * FROM sensors
22:15:20:776 Sqlite sensors: sid = 1
22:15:20:776 Sqlite sensors: name = Daylight
22:15:20:776 Sqlite sensors: type = Daylight
22:15:20:776 Sqlite sensors: modelid = PHDL00
22:15:20:776 Sqlite sensors: manufacturername = Philips
22:15:20:776 Sqlite sensors: uniqueid = 00:21:2e:ff:ff:06:c9:be-01
22:15:20:776 Sqlite sensors: swversion = 1.0
22:15:20:776 Sqlite sensors: state = {"dark":true,"daylight":false,"lastupdated":"2026-07-04T20:12:53.649","status":200,"sunrise":"2026-07-04T03:25:54","suns            et":"2026-07-04T19:50:07"}
22:15:20:776 Sqlite sensors: config = {"configured":true,"lat":"50.923500","long":"6.864600","on":true,"sunriseoffset":30,"sunsetoffset":-30}
22:15:20:776 Sqlite sensors: deletedState = normal
22:15:20:776 Sqlite sensors: mode = 1
22:15:20:776 DB found sensor Daylight 1
22:15:21:041 [INFO] - Setting environment variable 'TZ=:/etc/localtime'...
22:15:21:041 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:15:21:041 Started websocket server on REST-API HTTP(S) ports
22:15:21:058 [INFO] - Found file containing button maps. Parsing data...
22:15:21:074 [INFO] - Button maps loaded.
22:15:21:076 found node plugin: /usr/share/deCONZ/plugins/libde_rest_plugin.so - REST API Plugin
22:15:21:078 found node plugin: /usr/share/deCONZ/plugins/libstd_otau_plugin.so - STD OTAU Plugin
22:15:21:080 Node: id: 1, 00:21:2e:ff:ff:06:c9:be (0x00212EFFFF06C9BE) scene: 0.000000, 0.000000
22:15:21:084 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:06:c9:be-01' COLLATE NOCASE AND state != 'deleted'
22:15:21:084 DB pushZdpDescriptorDb()
22:15:21:119 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:15:21:134 auto connect com /dev/ttyACM0
22:15:21:155 dlg action: Read binding table
22:15:22:093 UPNP socket not bound, state: 0
22:15:22:168 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:15:22:217 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:15:22:232 auto connect com /dev/ttyACM0
22:15:22:233 gui/mainwindow: connect failed for idx 0
22:15:22:669 [Master] read param with arg 0x18
22:15:22:669 [Master] read param with arg 0x31
22:15:22:669 [Master] read param with arg 0x13
22:15:22:719 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:15:22:734 Device firmware version 0x26780700 ConBee II
22:15:22:734 unlocked max nodes: 512
22:15:22:737 Device protocol version: 0x010E
22:15:22:772 [Master] read param with arg 0x19
22:15:22:797 Current channel 15
22:15:22:817 CTRL ANT_CTRL 0x03
22:15:22:822 CTRL ZDP_RESPONSE handler 0x0001
22:15:22:827 CTRL read param resp id: 0x29, status: 0x04
22:15:22:837 CTRL read param resp id: 0x31, status: 0x04
22:15:22:852 CTRL read param resp id: 0x13, status: 0x04
22:15:22:867 APS-DATA.indication from unknown node 0xC433
22:15:22:888 APS-DATA.indication from unknown node 0x90AB96FFFE69D27C
22:15:22:898 APS-DATA.indication from unknown node 0x90AB96FFFE69D27C
22:15:23:149 wait reconnect 5 seconds
22:15:23:244 node 0x00212EFFFF06C9BE leave wait state
22:15:24:149 wait reconnect 4 seconds
22:15:25:149 wait reconnect 3 seconds
22:15:26:149 wait reconnect 2 seconds
22:15:26:192 Announced to internet https://phoscon.de/discover
22:15:26:192 discovery server date: Sat, 04 Jul 2026 20:15:26 GMT
22:15:26:192     local time seems to be ok
22:15:26:192 discovery reply doesn't contain valid version info
22:15:26:439 New websocket 192.168.2.46:5806
22:15:27:148 wait reconnect 1 seconds
22:15:29:293 APS-DATA.indication from unknown node 0xBE25
22:15:29:380 APS-DATA.indication from unknown node 0x97AA
22:15:30:648 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:15:31:085 timer 1 triggerd
22:15:31:085 timer fired
22:15:31:085 rest_plugin: msg from: 8
22:15:33:415 API error 1, /config, unauthorized user
22:15:34:403 New websocket 192.168.2.46:52673
22:15:34:730 API error 1, /groups, unauthorized user
22:15:34:730 New websocket 192.168.2.46:65247
22:15:40:648 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:15:41:149 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
22:15:44:150 device disconnected reason: 1, device index: 1
22:15:45:149 networkState: CC_ReconnectNetwork
22:15:45:149 start reconnect to network
22:15:45:149 wait reconnect 15 seconds
22:15:45:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:15:46:149 wait reconnect 14 seconds
22:15:47:148 wait reconnect 13 seconds
22:15:48:149 wait reconnect 12 seconds
22:15:49:148 wait reconnect 11 seconds
22:15:50:148 wait reconnect 10 seconds
22:15:50:398 failed to reconnect to network try=1
22:15:50:648 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:15:51:148 wait reconnect 9 seconds
22:15:52:148 wait reconnect 8 seconds
22:15:52:217 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:15:53:149 wait reconnect 7 seconds
22:15:54:148 wait reconnect 6 seconds
22:15:55:149 wait reconnect 5 seconds
22:15:55:648 failed to reconnect to network try=2
22:15:56:148 wait reconnect 4 seconds
22:15:57:148 wait reconnect 3 seconds
22:15:58:148 wait reconnect 2 seconds
22:15:59:148 wait reconnect 1 seconds
22:15:59:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:15:59:195 auto connect com /dev/ttyACM0
22:16:00:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:00:228 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:00:242 auto connect com /dev/ttyACM0
22:16:00:242 gui/mainwindow: connect failed for idx 0
22:16:00:649 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:16:00:649 failed to reconnect to network try=3
22:16:00:681 Device firmware version 0x26780700 ConBee II
22:16:00:684 unlocked max nodes: 512
22:16:00:694 APS-DATA.indication from unknown node 0xC433
22:16:01:148 wait reconnect 5 seconds
22:16:01:565 CTRL skip creating node 0x90AB96FFFE69D27C while permit join is disabled
22:16:02:148 wait reconnect 4 seconds
22:16:03:149 wait reconnect 3 seconds
22:16:04:148 wait reconnect 2 seconds
22:16:05:148 wait reconnect 1 seconds
22:16:05:648 reconnect network done
22:16:10:649 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:16:14:150 device disconnected reason: 1, device index: 1
22:16:15:148 wait reconnect 15 seconds
22:16:15:221 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:16:148 wait reconnect 14 seconds
22:16:17:148 wait reconnect 13 seconds
22:16:18:149 wait reconnect 12 seconds
22:16:19:148 wait reconnect 11 seconds
22:16:19:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:20:148 wait reconnect 10 seconds
22:16:20:648 DB save zll database items 0x00000080
22:16:20:649 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('1', 'Daylight', 'Daylight', 'PHDL00', 'Philips', '00:21:2e:ff:ff:06:c9:be-01', '1.0', '{"dark":true,"daylight":false,"lastupdated":"2026-07-04T20:15:21.041","status":200,"sunrise":"2026-07-04T03:25:54","sunset":"2026-07-04T19:50:07"}', '{"configured":true,"lat":"50.923500","long":"6.864600","on":true,"sunriseoffset":30,"sunsetoffset":-30}', '', 'normal', '1', '', '')
22:16:20:667 DB saved in 18 ms
22:16:20:667 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:16:21:149 wait reconnect 9 seconds
22:16:22:149 wait reconnect 8 seconds
22:16:23:149 wait reconnect 7 seconds
22:16:24:149 wait reconnect 6 seconds
22:16:25:149 wait reconnect 5 seconds
22:16:26:149 wait reconnect 4 seconds
22:16:27:149 wait reconnect 3 seconds
22:16:28:149 wait reconnect 2 seconds
22:16:28:227 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:29:148 wait reconnect 1 seconds
22:16:29:180 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:29:195 auto connect com /dev/ttyACM0
22:16:30:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:30:228 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:30:242 auto connect com /dev/ttyACM0
22:16:30:243 gui/mainwindow: connect failed for idx 0
22:16:30:648 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:16:30:679 Device firmware version 0x26780700 ConBee II
22:16:30:694 unlocked max nodes: 512
22:16:31:149 wait reconnect 5 seconds
22:16:31:326 CTRL skip creating node 0x90AB96FFFE69D27C while permit join is disabled
22:16:32:149 wait reconnect 4 seconds
22:16:33:148 wait reconnect 3 seconds
22:16:34:149 wait reconnect 2 seconds
22:16:34:740 API error 1, /groups, unauthorized user
22:16:35:148 wait reconnect 1 seconds
22:16:40:648 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:16:45:048 device disconnected reason: 1, device index: 1
22:16:45:149 wait reconnect 15 seconds
22:16:45:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:46:149 wait reconnect 14 seconds
22:16:46:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:47:149 wait reconnect 13 seconds
22:16:48:148 wait reconnect 12 seconds
22:16:49:149 wait reconnect 11 seconds
22:16:50:149 wait reconnect 10 seconds
22:16:50:648 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:16:51:148 wait reconnect 9 seconds
22:16:52:149 wait reconnect 8 seconds
22:16:53:149 wait reconnect 7 seconds
22:16:54:148 wait reconnect 6 seconds
22:16:55:148 wait reconnect 5 seconds
22:16:55:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:56:148 wait reconnect 4 seconds
22:16:57:148 wait reconnect 3 seconds
22:16:58:149 wait reconnect 2 seconds
22:16:59:149 wait reconnect 1 seconds
22:16:59:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:16:59:196 auto connect com /dev/ttyACM0
22:17:00:181 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:17:00:229 COM: /dev/ttyACM0 : ConBee II : dresden elektronik ingenieurtechnik GmbH (0x1CF1/0x0030)
22:17:00:243 auto connect com /dev/ttyACM0
22:17:00:244 gui/mainwindow: connect failed for idx 0
22:17:00:649 Daylight now: sunsetEnd, status: 200, daylight: 0, dark: 1
22:17:00:678 Device firmware version 0x26780700 ConBee II
22:17:00:680 unlocked max nodes: 512
22:17:00:685 APS-DATA.indication from unknown node 0x6886
22:17:00:695 APS-DATA.indication from unknown node 0xBE25
22:17:00:700 APS-DATA.indication from unknown node 0x97AA
22:17:01:148 wait reconnect 5 seconds
22:17:01:566 CTRL skip creating node 0x90AB96FFFE69D27C while permit join is disabled
22:17:02:149 wait reconnect 4 seconds
22:17:03:148 wait reconnect 3 seconds
I added some information
Running on raspbian trixie 64 bit, tried deconz in stable and beta version. trixie is booted from a ssd usb drive. Additional a ccu usb device is attachted (as it was in debian buster). When I restart from the buster sd drive everything is working fine
pi@raspberrypi4:~ $ ls -l /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Jul  4 22:41 /dev/ttyACM0
pi@raspberrypi4:~ $ id pi
uid=1000(pi) gid=1000(pi) groups=1000(pi),4(adm),20(dialout),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),60(games),100(users),996(input),992(render),102(netdev),989(spi),988(i2c),986(gpio),108(lpadmin),984(docker)
systemctl cat deconz
# /usr/lib/systemd/system/deconz.service
[Unit]
Description=deCONZ: ZigBee gateway -- REST API
Wants=deconz-init.service
StartLimitIntervalSec=0
[Service]
User=1000
ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80
Restart=on-failure
RestartSec=30
AmbientCapabilities=CAP_NET_BIND_SERVICE CAP_KILL CAP_SYS_BOOT CAP_SYS_TIME
[Install]
WantedBy=multi-user.target
pi@raspberrypi4:~ $ uname -a
Linux raspberrypi4 6.18.34+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.18.34-1+rpt1 (2026-06-09) aarch64 GNU/Linux
pi@raspberrypi4:~ $ uname -m
aarch64
dmesg | grep -E “ttyACM|cdc_acm|usb|disconnect|reset|ConBee”
[    0.050194] usbcore: registered new interface driver usbfs
[    0.050216] usbcore: registered new interface driver hub
[    0.050242] usbcore: registered new device driver usb
[    0.872032] usbcore: registered new interface driver lan78xx
[    0.872059] usbcore: registered new interface driver smsc95xx
[    0.875273] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[    0.875280] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.875285] usb usb1: Product: xHCI Host Controller
[    0.875289] usb usb1: Manufacturer: Linux 6.18.34+rpt-rpi-v8 xhci-hcd
[    0.875293] usb usb1: SerialNumber: 0000:01:00.0
[    0.876013] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[    0.876020] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.876025] usb usb2: Product: xHCI Host Controller
[    0.876029] usb usb2: Manufacturer: Linux 6.18.34+rpt-rpi-v8 xhci-hcd
[    0.876033] usb usb2: SerialNumber: 0000:01:00.0
[    0.877463] usbcore: registered new interface driver uas
[    0.877505] usbcore: registered new interface driver usb-storage
[    0.879697] usbcore: registered new interface driver usbhid
[    0.879701] usbhid: USB HID core driver
[    1.123458] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.262247] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    1.262266] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.262272] usb 1-1: Product: USB2.0 Hub
[    1.384136] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[    1.407709] usb 2-2: New USB device found, idVendor=0bda, idProduct=9201, bcdDevice=f2.00
[    1.407733] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.407739] usb 2-2: Product: Ugreen Storage Device
[    1.407744] usb 2-2: Manufacturer: Ugreen
[    1.407748] usb 2-2: SerialNumber: 133309276968
[    1.443519] usb 2-2: enable of device-initiated U1 failed.
[    1.445570] usb 2-2: disable of device-initiated U1 failed.
[    1.473379] usb 2-2: enable of device-initiated U1 failed.
[    1.556990] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[    1.652514] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=8c07, bcdDevice= 1.01
[    1.652533] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.652538] usb 1-1.3: Product: HB-RF-USB-2
[    1.652543] usb 1-1.3: Manufacturer: Alexander Reinert
[    1.652548] usb 1-1.3: SerialNumber: 269e1e2a1fc1e811ba506a713b0549ec
[    1.735424] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[    1.832033] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[    1.832051] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.832057] usb 1-1.4: Product: ConBee II
[    1.832063] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[    1.832067] usb 1-1.4: SerialNumber: DE2414017
[    5.298066] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[    5.298174] usbcore: registered new interface driver cdc_acm
[    5.298180] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    5.409615] usb 1-1.3: DKey: 6132653165393632 3131386531636631 3137613630356162 6365393435306233
[    5.409635] usb 1-1.3: HKey: 078bf315cbf2af4b 37dc10a817963a5a 5f07795a21d5b164 2dda7db2bfde4f7c
[    5.409640] usb 1-1.3: SKey: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[    5.409645] usb 1-1.3: SKey: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[    5.409650] usb 1-1.3: PKey: f50048a8d7cc3f44 ae8460d13cf61d60 2dc161f5272a5876 88c996b27737fbae
[    5.409654] usb 1-1.3: PKey: dd24b0aced521e88 cc457acb4b7c49a4 6745032ab2079847 becfb9f3af25d41f
[    5.409662] usb 1-1.3: Could not verify device signature
[    5.409669] usb 1-1.3: Found HB-RF-USB-2 with serial 269e1e2a1fc1e811ba506a713b0549ec at usb-0000:01:00.0-1.3
[    5.582472] raw-uart raw-uart1: Registered new raw-uart device using underlying device HB-RF-USB-2@usb-0000:01:00.0-1.3.
[    5.590894] usbcore: registered new interface driver hb_rf_usb_2
[    5.760207] usbcore: registered new interface driver brcmfmac
found it! I have cuxd running in openccu and cuxd connected to the conbee. I have no idea why and how I can change this, but if I stop the ccu docker container, everything worked fine… until I installed the old backup.
I had to set a new password, the old did not work anymore. I can see all my devices, but in the gateway option there is again a not connected in the firmware line.
Here is the log, looks different (too long for here): pi@raspberrypi4:~ $ /usr/bin/deCONZ -platform minimal --http-port=80 --dbg-info= - Pastebin.com
For me you have problem with your OS. No connection with the gateway.
You can try the command
GCFFlasher_internal -l
If this one don’ty see the geteway, not usefull to run Deconz.
I thought you were using a real OS. , if you want to use docker try GitHub - deconz-community/deconz-docker · GitHub
