I need your assistant if it’s possible :).
I have a display problem after installing the new IKEA Vindstyrka sensor.
It seems to work since Deconz but i can’t show the values pm2_5 and tVOC on HomeAssistant.
deCONZ Configuration with the value :
I can’t see this value on H.A.
When I look at other posts the value is written “particulate matter”.
Do you have any idea what I need to do?
Best Regards,
How did you pair the device in Deconz?
I’m trying but unsuccessfully.
Reset the device first then try to pair it.
Tks,
I found that in the late night.
Hello @LeoeLeoeL Have you successfully paired your device?
Do you have the same values as me?
Dabu99
April 22, 2023, 6:00am
6
Same problem. Would really love to see the answer how to integrate the pm2.5 values into home assistant.
The PPB value IS the tVoc value, though
Robban
April 23, 2023, 11:37am
8
Pm25 will be available with this PR. Probably in hass 2023.5
home-assistant:dev ← m4k2k:dev
opened 11:17PM - 10 Feb 23 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
**NO BREAKING CHANGES**
## MERGE ORDER
Needs to be merged once [pydeconz PR #408](https://github.com/Kane610/deconz/pull/408) ✅ is merged
## Proposed change
bump dependency pydeconz to [v111](https://github.com/Kane610/deconz/releases/tag/v111)(click for changelog)
### Goal:
Add support for [Tuya Smart Air Housekeeper](https://zigbee.blakadder.com/Tuya_DCR-KQG.html) (aka TS0601 | _TZE200_dwcarsat)
### Introduction:
This PR is a part of series of PR's affecting the repos: deconz-rest-plugin, pydeconz, homeassistant.
### Reference:
- https://github.com/dresden-elektronik/deconz-rest-plugin/pull/6739
- https://github.com/dresden-elektronik/deconz-rest-plugin/pull/6673
- https://github.com/Kane610/deconz/pull/408
### Technical Details:
- https://github.com/home-assistant/core/commit/98e3dccc892a76734f1a7d1a9bd22ce03ff00b4b works together with https://github.com/Kane610/deconz/commit/f9bca6db80fb5e19871bbea1f210cfd70a556188 and enable a check if the sensor entity should be created / if there is a value supplied by deconz-rest-api via pydeconz
- https://github.com/home-assistant/core/commit/13fd7c29b0442c25bfa370d3dccc3af884fe0c33 imports / prepare for the new sensor entities
- https://github.com/home-assistant/core/commit/21505ad575a4787e20819017aee8b77bc35063c5 adding the formaldehyde sensor entity
- https://github.com/home-assistant/core/commit/1580c952cd78f5f0d98312219da9b0d83061d5a1 adding the co2 sensor entity
- https://github.com/home-assistant/core/commit/7b5e7e72e3046c407c4a878c73c83ad8a5f9737d adding the pm25 sensor entity
**HINT** as of Arch Discussion: [#858](https://github.com/home-assistant/architecture/discussions/858) best practise for voc sensors which use ppb is to have no device_class (airqualityppb)
### POC:
**Proof Of Concept is already up and running**, result in HA once all PR's are merged:
<img src="https://user-images.githubusercontent.com/7247710/218211736-31f7a685-26bf-4da8-81d0-e179764ed374.png" width="400">
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [x] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #89708 (pydeconz v111)
- This PR is related to issue: https://github.com/dresden-elektronik/deconz-rest-plugin/issues/5889
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
I updated the firmware using Deconz.
I hoped for decimals in temperature readings but not.
mmiii
October 16, 2023, 3:40pm
10
Hi, is there now a solution for displaying PM2.5 values in HA, similar to FHEM?
In the system, I can read the following values:
Temperature (°C)
Humidity (%)
Air quality PM2.5 (excellent, good, etc.)
Air quality (ppb)
Air quality tVOC (excellent, good, etc.)
What I’m missing is the exact value of air quality PM2.5 in µg/m³. This specific value is presented to me in the deCONZ GUI as “042A PM2.5 measurement,” and I can read it there.
Regrettably, my knowledge is limited in this area, and I’m unable to solve the problem on my own.
I’d appreciate any assistance. Thank you.
