Hi Smanar, yes I created a DDF (see below). It shows up in the API, but the values are not updated - also not if I try manually to read in deCONZ GUI. On the other hand, the values on the LCD display are fine. You said you included it already, did you do anything special?
@Mimiix hope it is OK to continue the discussion a bit here
"manufacturername": "_TZE200_znbl8dj5",
"modelid": "TS0601",
"vendor": "Aubess",
"product": "TS0601",
"sleeper": true,
"status": "Gold",
"path": "/devices/aubess_temp_hum_ts0601_local.json",
"restapi": "/sensors",
"0x01",
"0x0402"
"name": "attr/swversion"
"name": "config/battery",
"at": "0x0021",
"cl": "0x0001",
"eval": "Item.val = Attr.val / 2",
"fn": "zcl"
"default": 0
"name": "config/offset",
"default": 0
"name": "config/on"
"name": "config/reachable"
"name": "state/lastupdated"
"name": "state/temperature",
"at": "0x0000",
"cl": "0x0402",
"eval": "Item.val = Attr.val + R.item('config/offset').val",
"fn": "zcl"
"default": 0
"0x01",
"0x0405"
"at": "0x0015",
"cl": "0x0001",
"fn": "zcl"
"default": 0
"description": "Relative offset to the main measured value.",
"default": 0
"name": "config/on"
"name": "state/humidity",
"at": "0x0000",
"cl": "0x0405",
"fn": "zcl"
"default": 0
"bindings": [
"cl": "0x0402",
"at": "0x0000",
"dt": "0x29",
"min": 60,
"max": 3600,
"change": "0x00000032"
"cl": "0x0405",
"at": "0x0000",
"dt": "0x21",
"min": 60,
"max": 3600,
"change": "0x00000064"
