Aqara Wall Outlet N2 EU
lumi.plug.aeu001
  • bound it to my Conbee III and downloaded the DDF
  • pasted unmodified content here below
  "manufacturername": "$MF_AQARA",
  "modelid": "lumi.plug.aeu001",
  "product": "lumi.plug.aeu001",
  "sleeper": false,
  "status": "Draft",
      "type": "$TYPE_POWER_SENSOR",
      "restapi": "/sensors",
        "0x01",
        "0x0b04"
      "fingerprint": {
        "profile": "0x0104",
        "device": "0x0000",
        "endpoint": "0x01",
        "in": [
          "0x0B04",
          "0x0000",
          "0xFCC0"
          "name": "attr/mode",
          "description": "Operational mode.",
          "default": 1
          "name": "attr/swversion"
          "name": "config/on"
          "name": "config/reachable"
          "name": "config/temperature",
          "description": "The current device temperature in °C."
          "name": "state/current",
          "description": "The measured current (in mA).",
          "refresh.interval": 300,
          "default": 0
          "name": "state/lastupdated"
          "name": "state/power",
          "description": "The measured power (in W).",
          "default": 0
          "name": "state/voltage",
          "description": "The measured voltage (in V).",
          "default": 0
        "0x15",
        "0x000c"
      "fingerprint": {
        "device": "0x0051",
        "endpoint": "0x15",
        "in": [
          "0x000C",
          "0x0000"
          "default": 1
          "name": "config/on"
          "default": 0
        "0x01",
        "0x0702"
      "fingerprint": {
        "device": "0x0000",
        "endpoint": "0x01",
        "in": [
          "0x0702",
          "0x0000",
          "0xFCC0"
          "default": 1
          "name": "config/on"
          "name": "state/consumption",
          "description": "The measured consumption (in Wh).",
          "default": 0
          "default": 0
  "bindings": [
      "dst.ep": 1,
      "cl": "0x0006"
      "src.ep": 2,
      "dst.ep": 1,
      "cl": "0x0006"
and let me guess, you miss the power/consumption measurement ?
Perhaps you can copy/paste some stuff from this ne ? deconz-rest-plugin/devices/xiaomi/xiaomi_sp-euc01_smart_plug.json at master · dresden-elektronik/deconz-rest-plugin · GitHub
Please post on GitHub…
hi, no it is more the “type”: “$TYPE_SMART_PLUG”, I am missing. I want to switch it on and off
Interestingly in Phoscon App two (!) devices have been populated (w./o. that DDF here in this threat separately deployed):
  1. On/Off Light (which can be switched on and off) AND
  2. A plug with all power and consumptions attributes
So, for me it is fine so even it looks a bit strange.
I don’t use Phoscon but in the APÏ (if you look at the DDF), you need to have 3 entries.
  • a light entry (that use the on/off command)
  • a sensor entry for consumption
  • a sensor entry for Power.
@Smanar Agree. I use DeCONZ app too (not Phoscon). Meanwhile, I did check the DDF again, it is different. And, as you described it has a third section “On/Off light”.
@Mimiix Where can I upload that DDF?
  "sleeper": false,
  "status": "Draft",
  "path": "/devices/lumi.plug.aeu001.json",
      "type": "$TYPE_ON_OFF_LIGHT",
      "restapi": "/lights",
        "0x01"
          "name": "state/alert",
          "description": "The currently active alert effect.",
          "default": "none"
          "name": "state/on",
          "description": "True when device is on; false when off.",
          "refresh.interval": 5
          "name": "state/reachable"
      "type": "$TYPE_SMART_PLUG",
        "0x02"
          "default": "none"
          "name": "state/on",
        "0x01",
        "0x0b04"
      "fingerprint": {
        "device": "0x0000",
        "endpoint": "0x01",
        "in": [
          "0x0B04",
          "0x0000",
          "0xFCC0"
          "default": 1
          "name": "config/on"
          "default": 0
          "default": 0
          "default": 0
        "0x15",
        "0x000c"
      "fingerprint": {
        "device": "0x0051",
        "endpoint": "0x15",
        "in": [
          "0x000C"
          "default": 1
          "name": "config/on"
          "default": 0
        "0x01",
        "0x0702"
      "fingerprint": {
        "device": "0x0000",
        "endpoint": "0x01",
        "in": [
          "0x0702",
          "0x0000",
          "0xFCC0"
          "default": 1
          "name": "config/on"
          "default": 0
          "default": 0
  "bindings": [
      "src.ep": 2,
      "dst.ep": 1,
      "cl": "0x0006",
          "at": "0x0000",
          "dt": "0x10",
          "min": 1,
          "max": 300
      "dst.ep": 1,
      "cl": "0x0006",
          "at": "0x0000",
          "dt": "0x10",
          "min": 1,
          "max": 300
The DDF you have posted previously is not used, it have the “Draft” Status.
Correct. I just saved it from DeCONZ app to here as I do not know where to file it for test / publication. And I am not sure whether or not it is on me to set the status to other than draft.
If you want to, you can make a PR on GitHub :slight_smile:
Just for information, you have 2 time the same bind on your DDF, one on the endpoint 0x02, and I don’t think your device have this DDF
And you miss the TYPE_SMART_PLUG, you have only the sensors part.
Can take this one as sample deconz-rest-plugin/devices/xiaomi/xiaomi_sp-euc01_smart_plug.json at master · dresden-elektronik/deconz-rest-plugin · GitHub
@Smanar Pls. refer to the last one I posted here. It is totally different from the first one. It has the following subdevices:
  • TYPE_ON_OFF_LIGHT
  • TYPE_SMART_PLUG
  • TYPE_POWER_SENSOR
  • TYPE_POWER_SENSOR (yes, 2 times)
  • TYPE_CONSUMPTION_SENSOR
Next, I removed the device from the network and let it rejoin. The DDF I read from DeCONZ is now similiar to the first one again. :frowning: I will experiement araound to find the right config.
Oups, sorry, my bad.
But for me you can remove the TYPE_ON_OFF_LIGHT, the TYPE_SMART_PLUG is enought.
I haven’t the node picture but from this comment on another forum.
Shows 2 switches when this is a single unit (switch_1 does nothing when turning on/off, switch_2 turns device on/off)
I think the device have 2 endpoints, but only one is working ? So you can use only “0x02” and remove all part with “0x01”. On your DDF the TYPE_SMART_PLUG use the endpoint 0x02 and the TYPE_ON_OFF_LIGHT the 0x01.
(Or the reverse, IDK the device is using)
You have 1 TYPE_POWER_SENSOR on endpoint 0x15, cluster 0x000C and another one on endpoint 0x01 cluster 0x0b04, I don’t think both are working ?
ATM you haven’t set bind/report, so deconz is polling your device every 300s. Look at your bind table, you have a bind only for the cluster 0x0006 (so for the on/off) but for endpoint 0x01 and 0x02, and from the previous comment it seem only one is usefull.
And there is no bind /report for the ZHAPower and ZHAConsumption.
