I’m using the Aqara vibration sensor (DJT11LM) on my windows to detect possible glass breaking. The sensors will then trigger my alarmsystem. To connect my Zigbee devices, I use the Raspbee II with the newest firmware/version.
After I discovered that the sensors generate false/positives especially at windy days, I changed the sensitivity via the REST-API using curl -H 'Content-Type: application/json' -X PUT -d '{"sensitivity": 15}' http://myIP/api/myAPIKey/sensors/5/config.
This works fine for every sensor and I always get a “success” back. However, when I check the config of the sensors using curl -X GET http://myIP/api/myAPIKey/sensors/5
I get the following configurations back:
{"config":{"battery":100,
"duration":65,
"on":true,
"reachable":false,
"sensitivity":15,
"sensitivitymax":2,
"temperature":3300},
"ep":1,
"etag":"ed8e5316d097634e4f2b5eb2538ce915",
"lastannounced":null,
"lastseen":"2023-08 25T19:05Z",
"manufacturername":"LUMI",
"modelid":"lumi.vibration.aq1",
"name":"Terassentür Vibrationssensor",
"state":{"lastupdated":"2023-08-25T18:30:30.316",
"orientation":[2,-73,17],
"tiltangle":5,
"vibration":false,
"vibrationstrength":10},
"swversion":"0.0.0_0008",
"type":"ZHAVibration",
"uniqueid":"00:15:8d:00:08:52:8f:62-01-0101"}
What’s making me curious is that the sensitivitymax is set to 2 which conflicts with many documentations that can be found for the Aqara vibration sensor which say that the sensitivity ranges from 1-21. Can someone tell me what’s wrong with my sensitivitymax or how I can reset it to be 21 as it should be? I read many articles about this issue but non seems to have a real solution.
Thank you guys in advance!
Greetings, Berger
