I use a Conbee II Stick attached to a raspberry pi 4 running home bridge and phoscon (2.25.1).
I have multiple sensor from Aqara and Sonoff.
My Aqara Vibration Sensor is the only troubling device.
It doesn’t keep the “sensitivity” setting I PUT via API. When checking API the setting is changed (from 2 to 1), but after some time it resets to 2.
I also tried pushing the button on the sensor before, while and after using PUT via API.
Interestingly I also changed the value for “duration” from 65 to 30. This value sticks and the EVE-App now also always reports a duration of 30 seconds when the sensor is triggered.
What’s wrong with the sensitivity value not sticking?
Any ideas?
THX and BR
ridgemont
