I’m using deCONZ + Homebridge with a Conbee II. My Aqara Vibration sensor is on my mailbox, but the wind trigger a lot of time the mailbox. I searched on google how to change the sensitvity but only found for Homeassistant.
This was how I solved this issue (I too have a sensor on my mailbox and for the last couple months the wind has made it unbearable; no issue prior to that).
I changed the sensitivity to a 9 from a 1 and so far so good:
curl -H 'Content-Type: application/json' -X PUT -d '{"sensitivity": 9}' http://192.168.1.115:8081/api/[APIKEY]/sensors/17/config
