Thank you, you too
I found in https://www.aqara.com/us/temperature_humidity_sensor.html:
"11. How often does the Temperature and Humidity Sensor upload data?
If the temperature humidity and atmospheric pressure varies a bit only, data will be reported once an hour. If the temperature variation exceeds 0.5℃, the humidity variation exceeds 6% and the atmospheric pressure is no less than 25Pa, data will be reported instantly."
