I received two of these smoke sensors today and am trying to follow up on the github thread that has been closed a while ago due to lack of response.
This is my first attempt to use the DDF editor to at least deliver the basic file Smanar was asking for. But I just do not get how to use the DDF editor. I select the device that I need to add and choose “edit DDF” this opens an Untitled file with prefilled modelid lumi.sensor_smoke.acn03 and Manufacturer LUMI as basic information. Then I enable the sleeper option and drag the ZHAFire to the left side of the window.
I checked the attributes and assume all I should change maybe is the settings for the fire attribute?
Here is where I get lost and do not know where to go from here. I have set the file on bronze and enabled bronze in the DDF options of deCONZ. I saved the file at this point and did a hot reload. Rescanned the devices and nothing seems to have changed.
When opening the ddf file on the device again the file I saved is opened so it has loaded it. I see the option to select the different parse options, including Xiaomi: special. But have no clue what to set in this. I have tried to read through documentation but am stuck here.
How can I get this moving forward to the REST API?
