I recently bought 3 Aqara curtain drivers. Before I ordere I sew some posts that it should work… But I can’t connect it:
Aqara Curtain Driver E1 rod version
CM-M01
trying to pair it as a light:
23:15:01:683 APS-DATA.request id: 252, addrmode: 0x03, addr: 0x00158d0004720608, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 0 len: 5 tx.options 0x00
23:15:01:747 APS-DATA.confirm id: 252, status: 0x00 SUCCESS
23:15:01:748 APS-DATA.confirm request id: 252 -> erase from queue
23:15:01:770 APS-DATA.indication srcAddr: 0x0f66, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 255, rssi: -67
23:15:01:772 APS-DATA.request id: 252 erase from queue
23:15:01:774 ZCL got data for node=0x0F66, cl=0x0006, at=0x0000, status=0x00, type=0x10
23:15:01:775 APS-DATA.request id: 254, addrmode: 0x02, addr: 0x0f66, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 0 len: 5 tx.options 0x04
23:15:01:814 APS-DATA.confirm id: 254, status: 0x00 SUCCESS
23:15:01:815 APS-DATA.confirm request id: 254 -> erase from queue
23:15:01:817 aps request id: 254 finished, erase from queue
23:15:02:774 Mgmt_Lqi_req zdpSeq: 167 to 0x60A423FFFEC76E9A start index 0
23:15:02:776 APS-DATA.request id: 3, addrmode: 0x03, addr: 0x60a423fffec76e9a, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
23:15:02:822 APS-DATA.confirm id: 3, status: 0x00 SUCCESS
23:15:02:824 APS-DATA.confirm request id: 3 -> confirmed, timeout 2261695
23:15:02:895 APS-DATA.indication srcAddr: 0xaeb1, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 255, rssi: -55
23:15:02:896 APS-DATA.indication request id: 3 -> finished
23:15:02:897 APS-DATA.request id: 3 erase from queue
23:15:02:898 ZDP 0x60A423FFFEC76E9A cluster: 0x8031 status = 0x00 -> SUCCESS
23:15:02:899 ZDP Mgmt_Lqi_rsp zdpSeq: 167 from 0x60A423FFFEC76E9A total: 8, startIndex: 0, listCount: 3
23:15:02:900 * neighbor: 0x00212EFFFF052DF9 (0x0000), LQI: 210, relation: 0x00, depth: 0, rxOnWHenIdle: 1
23:15:02:901 * neighbor: 0x00158D0004720608 (0x0F66), LQI: 172, relation: 0x02, depth: 15, rxOnWHenIdle: 1
23:15:02:902 ZDP add 0x00158D0004720608, nwk: 0x0F66 to discover queue
23:15:02:903 * neighbor: 0xBC33ACFFFE64B2AA (0x6678), LQI: 91, relation: 0x02, depth: 15, rxOnWHenIdle: 1
23:15:02:904 ZDP add 0xBC33ACFFFE64B2AA, nwk: 0x6678 to discover queue
23:15:04:962 APS-DATA.indication srcAddr: 0x219e, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0102, lqi: 255, rssi: -43
23:15:04:965 ZCL attribute report 0x842E14FFFE57FA27 for cluster: 0x0102, ep: 0x01, frame control: 0x08, mfcode: 0x0000
23:15:04:970 APS-DATA.request id: 14, addrmode: 0x02, addr: 0x219e, profile: 0x0104, cluster: 0x0102, ep: 0x01 -> 0x01 queue: 0 len: 5 tx.options 0x04
23:15:04:972 APS-DATA.request id: 15, addrmode: 0x03, addr: 0x842e14fffe57fa27, profile: 0x0000, cluster: 0x0021, ep: 0x00 -> 0x00 queue: 1 len: 22 tx.options 0x04
23:15:05:010 APS-DATA.confirm id: 14, status: 0x00 SUCCESS
23:15:05:012 APS-DATA.confirm request id: 14 -> erase from queue
23:15:05:015 aps request id: 14 finished, erase from queue
23:15:05:242 APS-DATA.indication srcAddr: 0x219e, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8021, lqi: 255, rssi: -43
23:15:05:244 APS-DATA.indication request id: 15 -> finished? not confirmed
23:15:05:245 ZDP 0x842E14FFFE57FA27 cluster: 0x8021 status = 0x00 -> SUCCESS
23:15:05:247 Bind response success for 0x842e14fffe57fa27 ep: 0x01 cluster: 0x0000
23:15:05:258 APS-DATA.confirm id: 15, status: 0x00 SUCCESS
23:15:05:259 APS-DATA.confirm request id: 15 -> finished, timeout 2263928
23:15:05:260 aps request id: 15 finished, erase from queue
23:15:06:083 APS-DATA.request id: 21, addrmode: 0x02, addr: 0xfffc, profile: 0x0000, cluster: 0x0036, ep: 0x00 -> 0x00 queue: 0 len: 3 tx.options 0x00
23:15:06:085 send permit join, duration: 65
23:15:06:087 APS-DATA.request id: 22, addrmode: 0x02, addr: 0xfffc, profile: 0xA1E0, cluster: 0x0021, ep: 0xF2 -> 0xF2 queue: 1 len: 6 tx.options 0x00
23:15:06:135 skip device discovery while end devices is added
23:15:06:222 APS-DATA.confirm id: 22, status: 0x00 SUCCESS
23:15:06:295 aps request id: 22 finished, erase from queue
23:15:06:615 skip device discovery while end devices is added
23:15:06:790 APS-DATA.confirm id: 21, status: 0x00 SUCCESS
23:15:06:860 aps request id: 21 finished, erase from queue
23:15:07:083 APS-DATA.request id: 26, addrmode: 0x02, addr: 0xfffc, profile: 0x0000, cluster: 0x0036, ep: 0x00 -> 0x00 queue: 0 len: 3 tx.options 0x00
23:15:07:084 send permit join, duration: 65
23:15:07:086 APS-DATA.request id: 27, addrmode: 0x02, addr: 0xfffc, profile: 0xA1E0, cluster: 0x0021, ep: 0xF2 -> 0xF2 queue: 1 len: 6 tx.options 0x00
23:15:07:118 skip device discovery while end devices is added
23:15:07:222 APS-DATA.confirm id: 27, status: 0x00 SUCCESS
23:15:07:254 aps request id: 27 finished, erase from queue
23:15:07:575 skip device discovery while end devices is added
23:15:07:786 APS-DATA.confirm id: 26, status: 0x00 SUCCESS
23:15:07:814 aps request id: 26 finished, erase from queue
23:15:08:054 skip device discovery while end devices is added
23:15:08:534 skip device discovery while end devices is added
23:15:09:015 skip device discovery while end devices is added
23:15:09:494 skip device discovery while end devices is added
23:15:09:974 skip device discovery while end devices is added
23:15:10:110 APS-DATA.indication srcAddr: 0x9b19, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0xFCC0, lqi: 255, rssi: -55
23:15:10:112 ZCL attribute report 0x54EF4410005582B8 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
23:15:10:454 skip device discovery while end devices is added
23:15:10:934 skip device discovery while end devices is added
23:15:11:415 skip device discovery while end devices is added
23:15:11:895 skip device discovery while end devices is added
23:15:12:375 skip device discovery while end devices is added
23:15:12:855 skip device discovery while end devices is added
23:15:13:334 skip device discovery while end devices is added
23:15:13:814 skip device discovery while end devices is added
23:15:14:294 skip device discovery while end devices is added
23:15:14:454 MAC Poll 0x02 0x96F7, life time: 8 sec, dev timeout: 61440 sec
23:15:14:522 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x0013, lqi: 255, rssi: -49
23:15:14:524 unknown node 0x54EF4410005582B8 (0x96F7), lqi: 255
23:15:14:525 0x9B19 nwk changed to 0x96F7
23:15:14:526 ZDP device announce: 0x54EF4410005582B8, 0x96F7, 0x84
23:15:14:528 ZDP add 0x54EF4410005582B8, nwk: 0x96F7 to discover queue
23:15:14:529 device announce 0x54EF4410005582B8 (0x96F7) mac capabilities 0x84
23:15:14:530 set fast probe address to 0x54EF4410005582B8 (0x96F7)
23:15:14:531 FP indication 0x0000 / 0x0013 (0x54EF4410005582B8 / 0x96F7)
23:15:14:532 ... (0x54EF4410005582B8 / 0x96F7)
23:15:14:533 device announce 0x54EF4410005582B8 (0x96F7) mac capabilities 0x84
23:15:14:534 DEV Tick.Join: event/device.anounce
23:15:14:535 DEV Tick: fast poll 0x54EF4410005582B8, mac capabilities: 0x84
23:15:14:775 skip device discovery while end devices is added
23:15:14:792 MAC Poll 0x02 0x96F7, life time: 15000 sec, dev timeout: 61440 sec
23:15:14:896 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:14:000 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:14:001 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:15:100 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:15:171 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0000, lqi: 255, rssi: -49
23:15:15:172 FP indication 0x0104 / 0x0000 (0x54EF4410005582B8 / 0x96F7)
23:15:15:172 ... (0x54EF4410005582B8 / 0x96F7)
23:15:15:173 ZCL attribute report 0x54EF4410005582B8 for cluster: 0x0000, ep: 0x01, frame control: 0x18, mfcode: 0x0000
23:15:15:194 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0xFCC0, lqi: 255, rssi: -49
23:15:15:196 FP indication 0x0104 / 0xFCC0 (0x54EF4410005582B8 / 0x96F7)
23:15:15:198 ... (0x54EF4410005582B8 / 0x96F7)
23:15:15:199 ZCL attribute report 0x54EF4410005582B8 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
23:15:15:235 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0xFCC0, lqi: 255, rssi: -49
23:15:15:236 0x54EF4410005582B8 extract Xiaomi special attribute 0x00F7
23:15:15:237 01 battery 3000 (0x0BB8)
23:15:15:238 03 Device temperature 28 °C
23:15:15:240 05 RSSI dB (?) 1 (0x0001)
23:15:15:241 0a Parent NWK 0 (0x0000)
23:15:15:241 0c unknown 1 (0x01)
23:15:15:242 0d firmware 0.0.0_2727 (0x00001B1B)
23:15:15:243 64 lift 2 (98%)
23:15:15:244 64 smoke/gas density 2 (0x02)
23:15:15:244 65 battery 200%
23:15:15:245 66 unknown 3 (0x03)
23:15:15:246 67 unknown 0 (0x00)
23:15:15:247 68 unsupported tag (data type 0x21)
23:15:15:247 69 charging 1 (0x01)
23:15:15:248 6A unsupported tag (data type 0x20)
23:15:15:249 FP indication 0x0104 / 0xFCC0 (0x54EF4410005582B8 / 0x96F7)
23:15:15:250 ... (0x54EF4410005582B8 / 0x96F7)
23:15:15:251 ZCL attribute report 0x54EF4410005582B8 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
23:15:15:266 skip device discovery while end devices is added
23:15:15:270 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x000A, lqi: 255, rssi: -49
23:15:15:272 APS-DATA.request id: 64, addrmode: 0x02, addr: 0x96f7, profile: 0x0104, cluster: 0x000A, ep: 0x01 -> 0x01 queue: 0 len: 19 tx.options 0x00
23:15:15:274 FP indication 0x0104 / 0x000A (0x54EF4410005582B8 / 0x96F7)
23:15:15:275 ... (0x54EF4410005582B8 / 0x96F7)
23:15:15:330 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0xFCC0, lqi: 255, rssi: -49
23:15:15:332 FP indication 0x0104 / 0xFCC0 (0x54EF4410005582B8 / 0x96F7)
23:15:15:333 ... (0x54EF4410005582B8 / 0x96F7)
23:15:15:334 ZCL attribute report 0x54EF4410005582B8 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
23:15:15:358 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0001, lqi: 255, rssi: -49
23:15:15:360 FP indication 0x0104 / 0x0001 (0x54EF4410005582B8 / 0x96F7)
23:15:15:361 ... (0x54EF4410005582B8 / 0x96F7)
23:15:15:363 ZCL attribute report 0x54EF4410005582B8 for cluster: 0x0001, ep: 0x01, frame control: 0x18, mfcode: 0x0000
23:15:15:387 [1] get node descriptor for 0x54ef4410005582b8
23:15:15:388 ZDP get node descriptor for 0x96F7
23:15:15:390 APS-DATA.request id: 68, addrmode: 0x03, addr: 0x54ef4410005582b8, profile: 0x0000, cluster: 0x0002, ep: 0x00 -> 0x00 queue: 1 len: 3 tx.options 0x00
23:15:15:735 skip device discovery while end devices is added
23:15:16:136 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
23:15:16:154 APS-DATA.confirm id: 64, status: 0x00 SUCCESS
23:15:16:155 APS-DATA.confirm request id: 64 -> erase from queue
23:15:16:215 skip device discovery while end devices is added
23:15:16:216 aps request id: 64 finished, erase from queue
23:15:16:695 skip device discovery while end devices is added
23:15:17:132 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:17:166 APS-DATA.confirm id: 68, status: 0x00 SUCCESS
23:15:17:167 APS-DATA.confirm request id: 68 -> confirmed, timeout 2274309
23:15:17:174 skip device discovery while end devices is added
23:15:17:365 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:17:390 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8002, lqi: 255, rssi: -50
23:15:17:392 APS-DATA.indication request id: 68 -> finished
23:15:17:393 APS-DATA.request id: 68 erase from queue
23:15:17:394 ZDP 0x54EF4410005582B8 cluster: 0x8002 status = 0x00 -> SUCCESS
23:15:17:395 ZDP Node_Descriptor_rsp 0x54EF4410005582B8 - 0x96F7
23:15:17:408 APS-DATA.request id: 77, addrmode: 0x02, addr: 0x96f7, profile: 0x0000, cluster: 0x0005, ep: 0x00 -> 0x00 queue: 0 len: 3 tx.options 0x00
23:15:17:409 FP indication 0x0000 / 0x8002 (0x54EF4410005582B8 / 0x96F7)
23:15:17:410 ... (0x54EF4410005582B8 / 0x96F7)
23:15:17:411 ZDP indication search sensors 0x54EF4410005582B8 (0x96F7) cluster 0x8002
23:15:17:412 ZDP indication search sensors 0x54EF4410005582B8 (0x96F7) clear timeout on cluster 0x8002
23:15:17:419 [2] get active endpoints for 0x54ef4410005582b8
23:15:17:420 ZDP get active endpoints for 0x96F7
23:15:17:421 APS-DATA.request id: 78, addrmode: 0x03, addr: 0x54ef4410005582b8, profile: 0x0000, cluster: 0x0005, ep: 0x00 -> 0x00 queue: 1 len: 3 tx.options 0x00
23:15:17:655 skip device discovery while end devices is added
23:15:18:134 skip device discovery while end devices is added
23:15:18:143 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
23:15:18:162 APS-DATA.confirm id: 77, status: 0x00 SUCCESS
23:15:18:163 APS-DATA.confirm request id: 77 -> confirmed, timeout 2276327
23:15:18:353 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:18:354 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:18:370 APS-DATA.confirm id: 78, status: 0x00 SUCCESS
23:15:18:372 APS-DATA.confirm request id: 78 -> confirmed, timeout 2276340
23:15:18:394 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8005, lqi: 255, rssi: -50
23:15:18:396 APS-DATA.indication request id: 77 -> finished
23:15:18:397 APS-DATA.request id: 77 erase from queue
23:15:18:399 ZDP 0x54EF4410005582B8 cluster: 0x8005 status = 0x00 -> SUCCESS
23:15:18:400 ZDP active ep response for 0x54ef4410005582b8
23:15:18:401 ep: 0x01
23:15:18:402 FP indication 0x0000 / 0x8005 (0x54EF4410005582B8 / 0x96F7)
23:15:18:403 ... (0x54EF4410005582B8 / 0x96F7)
23:15:18:403 ZDP indication search sensors 0x54EF4410005582B8 (0x96F7) cluster 0x8005
23:15:18:404 ZDP indication search sensors 0x54EF4410005582B8 (0x96F7) clear timeout on cluster 0x8005
23:15:18:548 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:18:570 APS-DATA.indication srcAddr: 0x96f7, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8005, lqi: 255, rssi: -49
23:15:18:572 APS-DATA.indication request id: 78 -> finished
23:15:18:573 APS-DATA.request id: 78 erase from queue
23:15:18:575 ZDP 0x54EF4410005582B8 cluster: 0x8005 status = 0x00 -> SUCCESS
23:15:18:576 ZDP active ep response for 0x54ef4410005582b8
23:15:18:577 ep: 0x01
23:15:18:578 FP indication 0x0000 / 0x8005 (0x54EF4410005582B8 / 0x96F7)
23:15:18:579 ... (0x54EF4410005582B8 / 0x96F7)
23:15:18:580 ZDP indication search sensors 0x54EF4410005582B8 (0x96F7) cluster 0x8005
23:15:18:614 skip device discovery while end devices is added
23:15:19:095 skip device discovery while end devices is added
23:15:19:129 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:19:574 skip device discovery while end devices is added
23:15:20:054 skip device discovery while end devices is added
23:15:20:127 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
23:15:20:534 skip device discovery while end devices is added
23:15:21:014 skip device discovery while end devices is added
23:15:21:131 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:21:495 skip device discovery while end devices is added
23:15:21:975 skip device discovery while end devices is added
23:15:22:125 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
23:15:22:455 skip device discovery while end devices is added
23:15:22:934 skip device discovery while end devices is added
23:15:23:130 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:23:414 skip device discovery while end devices is added
23:15:23:894 skip device discovery while end devices is added
23:15:24:136 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
23:15:24:374 skip device discovery while end devices is added
23:15:24:855 skip device discovery while end devices is added
23:15:25:136 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:25:334 skip device discovery while end devices is added
23:15:25:814 skip device discovery while end devices is added
23:15:26:134 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
23:15:26:294 skip device discovery while end devices is added
23:15:26:775 skip device discovery while end devices is added
23:15:27:131 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:27:254 skip device discovery while end devices is added
23:15:27:735 skip device discovery while end devices is added
23:15:28:134 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
23:15:28:214 skip device discovery while end devices is added
23:15:28:694 skip device discovery while end devices is added
23:15:29:133 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:29:174 skip device discovery while end devices is added
23:15:29:654 skip device discovery while end devices is added
23:15:30:133 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
23:15:30:135 skip device discovery while end devices is added
23:15:30:614 skip device discovery while end devices is added
23:15:31:095 skip device discovery while end devices is added
23:15:31:136 MAC Poll 0x02 0x96F7, life time: 60000 sec, dev timeout: 61440 sec
23:15:31:575 skip device discovery while end devices is added
23:15:32:054 skip device discovery while end devices is added
23:15:32:140 MAC Poll 0x02 0x96F7, life time: 59998 sec, dev timeout: 61440 sec
Current setup:
Raspberry PI Ubuntu 64
Raspbee 2 + deconz ( version 2.20.00 / 19/09/2022 Firmware 26780700)
Btw:
I still need to: ln -s /dev/ttyS0 /dev/serial0 to get everything running.
Someone told me a year ago in discord that this would get solved in the near future
