When using Matter, does the FLS-M support Apple HomeKit adaptive lighting?
An FLS-M (firmware version 1.1) arrived. Sadly, it does not support Apple Home Adaptive Lighting. ![]()
I took a closer look, and it could be caused by:
If the Vendor App
supports XY
colorMode, the
accessory must
maintain accurate
mapping of XY ->
HS values after
changing the
color in the
Vendor App
This is not a mandatory feature in Matter, but I’ll check if I can implement it in the next firmware release.
That would be fantastic, please reach out if you’d like me to beta test. Thanks!
Any word on the next firmware version for FLS-M and if it will support Apple Home Adaptive Lighting or a dedicated color temperature (CT) field to the config builder (Color Calibration in FLS-M Config-Builder NOT Reflected in Matter Device)? Thanks!
Dunno how, because FLS-M is still on firmware 1.1, but at least as of iOS 26.6.1, the two Matter Color Temperature Light devices that I have configured support adaptive lighting in the Home app!
