Hi all,
Zshark (for sniffing Zigbee traffic) is now available for use with Conbee II !
https://phoscon.de/en/conbee2/software#zshark
Raspbee II is still a Work in Progress.
That’s all for now!
Thanks,
- Dennis / @Mimiix / https://discord.gg/3XGEYY9
Hi all,
That’s all for now!
Thanks,
Installed Zshark and it asked to upgrade firmware… Followed seamless procedure for upgrade, restart and connection works a treat. Sniffing yes. Excellent work.
One immediate issue was after closing down and running DeConz will now not connect.
Removed and retested and DeConz is now non-functional. I upgraded to DeConz 2.12.3 and still no luck so I need to look further later today.
You need to flash the original firmware back to it.
Thank you and I thought was the case.
Therefore a Conbee can only be employed in either one or the other role depending on firmware. Is there any plans to merge?
Not sure if that’s even possible
@ChrisHae Are you able to explain something about this?
The Zshark and deCONZ firmware are two different firmwares.
Each Application works in a different way and therefore needs an individual firmware.
(Both have a different underlying communication sw stack)
Thank you and appreciate that the firmware is role specific.
Is my understanding correct that we cannot use a ConBee II or RaspBee II for sniffing ZigBee traffic while in parallel use it for its original purpose, e.g. lights and sensors management? Anyway, thanks a lot for developing and supporting all these great tools!
That is correct, it is one or the other.
