All devices are not reachable. In Phoscon all devices are greyed out. Can not control any of them.
Probably it happened when I tried to put stick to another usb port. After I put it back but nothing helping. Tried to restart PC, restart deconz, restart conbee2…
OS (Ubuntu)
Firmware version: (26780700)
deCONZ version (not Home assistant Addon version!): (2.14.01 / 06.02.2022)
Device: (ConBee II)
Logs:
21:52:36:438 CTRL skip creating node 0x8CF681FFFEBBEAE9 while permit join is disabled
21:52:37:581 Idle timer triggered
21:52:37:581 Force read attributes for ZHAPressure SensorNode Multi Sensor
21:52:40:398 New websocket 192.168.10.118:38876 (state: 3)
21:52:41:081 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:52:41:081 apsUseExtPanid is 0xEBD66273F80D7F5B but should be 0, start reconfiguration
21:52:41:081 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF069331, start reconfiguration
21:52:41:081 Skip automatic channel change, TODO warn user
21:52:42:581 Idle timer triggered
21:52:42:581 Force read attributes for ZHATemperature SensorNode Multi Sensor (childrens room)
21:53:31:081 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF069331, start reconfiguration
21:53:31:081 Skip automatic channel change, TODO warn user
22:08:51:081 apsUseExtPanid is 0xEBD66273F80D7F5B but should be 0, start reconfiguration
I’m using zigbee2mqtt, but with another “Sonoff” stick. And everything was working fine until I tried to connect Conbee2 stick together with Sonoff dongle to one USB hub.
