my Silvercrest door and window contact sensor (Lidl) cannot be added with the Phoscon App or WebApp. First I rebooted this and that was the mistake - no connection any more to my Zigbee sensors. So I tried to debug with zhark. At the start of the zshark I got the message to update the firmware. So I did this and I could capture the zigbee. (a lot of FCS Bad checksum, but the sensors tried to communicate ). This shows me, that the devices works. After that I wanted to switch back to deCONZ App on the Raspberry Pi, but I couldn’t get a success connect. No error message or anything else - just the button get back to a clickable “connect”.
What can I do to fix this?
And is there a tip or procedure how I can verify that these sensors are joined correctly? (Press button and follow the instruction from the sensor is not the problem)
i have the same issue exept my conbee2 was allready in the last firmware before using Zshark, does it mean at each time i use zsahrk we have to flash the conbee again?
I’ve just had a similar problem I installed ZSHARK. I mistakenly clicked ‘OK’ on a dialog that said that something was missing / not present on the device firmware and that it needed to add / install something to the firmware on my ConBee device. I didn’t get any errors but I didn’t know enough about ZShark to know what to do next.
So I closed ZShark and reopened deCONZ but is failed to connect to my ConBee II device.
Thinking that the firmware had become corrupted I attempted to flash firmware onto the device using
the following as my first step. GCFFlasher -d COM7 -f …\firmware\deCONZ_Rpi_0x26400500.bin.GCF
( where COM7 is the port for ConBee II)
but I get an error writing the flash image.
Reboot device COM7 (ConBee II)
deCONZ firmware version 31000700
R21B18 Bootloader
Vers: 2.07
build: Jun 17 2019
flashing 127650 bytes: |=
dev: ERROR writing image (15 ms)
I tried several times and even re-aquired the firmware file from the deCONZ site
But same error each time. I decided to opt to Even though the first step failed, I opted to go on to the second step and flash the ‘ConbeeII’ file
I opened deCONZ and it successfully connected to my ConBee II device, and surprisingly, but thankfully my Zigbee network was still there, through 2 nodes which were for devices which I added to the network after the last time I created a backup in Phoscon didn’t show connection lines back to the coordinator. After several minutes one of these (an open/close sensor) did reattach to the network, but the other isn’t attaching (REST AI confirms that it is unreachable). My have to reset device and re-add it in Phoscon).
Anyway I’m taking it as a lesson and I’m not going back to use ZShark any time soon.
